c5 x7 wheels 2009 comfort
Results 1 to 14 of 14
  • 1 Post By David S
Thread: c5 x7 wheels 2009 comfort
    Dec 2016
    camden
    36
    Default c5 x7 wheels 2009 comfort
    Hi there, i'm after a set of OEM alloy wheels. They are 16" x 7" for a 225x 60 x 16 tyre. Would something off a pug suit?. Alternatively would 17" rims be a better option? Will the 16" and 17" wheels be the same diameter? thanks
    FYI I've had 3 citroens, 6 renaults and 5 peugeots over the years.
    Feb 2002
    Coolum Beach
    1,919
    Quote Originally Posted by cee5 View Post
    Only past ownership of Citroens is rewarded here, ownership of past Renaults and Peugeots is detrimental to your overall character.
    Sent from my GT-P5110 using aussiefrogs mobile app
    DS Un jour, DS toujours !
    DS23 IE Pallas Automatique
    C5 X7 163 Exclusive
    C3 II 2010
    Member MELso's Avatar
    May 2016
    77
    The wheels on 2009 C5 Comforts were 17x7 and the tyres 225/60R17.
    Hence you need 17" alloys because C5 X7s were never sold with 16" wheels here.
    2011 Citroen C5 - 'La Barge'
    8,775
    Wot 'e sed. 16 inch wheels are listed for some UK models. None used 225/60
    9,777
    There were a number of very early cars sold with 16 inch black rims that needed hubcaps and taller tyres to give the same rolling diameter. Try the wreckers for a set, but I think you will find the bolts are also different and that affects the spare. The spare wouldn't be an alloy rim, but is called a 'full sized' spare because it isn't a space-saver, but is a different rim / tyre combo. Basically, to do a conversion, the entire kit from a wreck would be needed rather than just a set of 4 rims. The steel rims are not so bad and the taller sidewall probably makes them a little more compliant. Not a bad thing really.
    Dec 2016
    camden
    36
    my car has 16" steel wheels hence he question.
    Dec 2016
    camden
    36
    Thanks David S. your spot on. so the stud pattern will be different to the steel wheels for oem 16" and 17" alloys.
    CitroŽn Tragic UFO's Avatar
    9,721
    I think you would find the stud pattern would be the same. David was referring to the studs which may be different to a car with 17, 18 or 19" alloy wheels. The length and shoulders may be different to alloy wheels.
    Dec 2016
    camden
    36
    Thanks Craig. I'll investigate further.
    Dec 2016
    camden
    36
    Wrong. I have 16" steel wheels.225x60x16 tyres
    9,777
    The stud pattern in the hub doesn't change, but the bolts will differ because the pressed steel rims are a thinner material than the aluminium rims. The steel spare rim that comes with a set of 4 aluminium rims either has raised sections at the bolt holes to mimic the thickness of the aluminium rim or the bolts are a special design to cope with both thicknesses. You'd just have to make sure you get a compatible set of 4 rims, the spare, bolts and I guess the tools if the bolt head size is different.
    The bolts intended for aluminium rims almost always have a flat or conical captive washer, whereas the bolts for steel rims typically don't. If you use the incorrect bolts and they seem to fit, you may end up with only a couple of thread turns engaging and that would be very dangerous. That was a trap with two types of Xantia rim that looked virtually the same but required two different lengths of bolt. Picking the shorter one with a rim needing the long one meant barely any thread engagement!
    UFO likes this.
    Dec 2016
    camden
    36
    Thanks David and Craig. I've just discovered that the spare is a steel wheel with a never used Michelin tyre 225x55x17. Without measuring I could assume that the overall diameter would be the same as the 225x60x16 on the car now. So I will start looking for 17" alloys. thanks for your help.
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    413
    Car parts online in Sydney are wrecking a couple if it helps.
    CITROEN C5 Used Spare Parts NSW AUSTRALIA
    Plus the have a tourer in the racks.
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
    Dec 2016
    camden
    36
    Thanks flipperman. I'll call when they open.
