D Special not rising in the front!
Results 1 to 25 of 50
Like Tree13Likes
Thread: D Special not rising in the front!
    3,581
    Default D Special not rising in the front!
    My newly acquired D special refuses to rise in the front. I suspect some air got in the system when at once stage she was low on LHM. Today I undid the hose at the tank end and put more LHM into the hose to feed into the pump. A trick Bruce Elsegood told me about years ago, and it worked! but not today on this one. Any other suggestions appreciated.
    Jul 2011
    Castlemaine VIC
    355
    You would have undid the valve (anticlockwise) to bleed the lines at the regulator but the D Special would need to be bled at the brake caliper, like the ID to expel any remaining air.
    Just a thought.
    All the Best ---- Michael
    Bad Bertie likes this.
    Ici.
    2,560
    is it leaking?
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    If the rear rises and the power steering works, you might have to clean out the front height corrector.
    Roger
    Mort Subite likes this.
    Apr 2014
    Phoenix, Arizona USA
    676
    Or, sometimes you can free it up by running the manual height control lever sharply from highest to lowest position several times.
    John T.
    Symar/ca/usa
    607
    Quote Originally Posted by Bad Bertie View Post
    As Roger noted, if the rear pressurizes and the steering works, you may wind up having to clean out the front HC. However, before going to that, remove front wing/tire and mud shield and ensure that the manual HC control (and being a RHD car - the all of those linkages going to the HC valve) are working as intended. LHD are a lot more simple as that control rod is basically a straight 'shot' to the front HC. Keep in mind that the control rod attached to the front 'anti-roll bar' is what sets the height of the car. Don't fool with it, at all, until the other problem(s) are resolved. And it's setting is a bit tricky - IOW it does not take much movement of it to greatly affect the cars 'normal' height and subsequently ride quality.
    Keep in mind that the HC's internal control valve only has to move, literally, a fraction of an inch to either allow pressure into or out of the suspension system. And any air in the system will not prevent the car from going up/down. It just gets shoved, under pressure, up to and inside the suspension spheres.
    Jun 2003
    Lauderdale, Tasmania
    2,887
    Viagra?
    Bounge and 59 Floride like this.
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Whats the HLM level in the holding tank?? Is there any HLM visible in the holding tank???
    It's how I roll...Brisbane
    33,176
    Quote Originally Posted by gerry freed View Post
    Viagra?
    Someone had to say it..
    9,777
    Viagra?
    No, I think he mistakenly named the car Souffle and is now expecting too much.
    Debris inside the HC is very likely. Try a jack (low profile!) under the left jacking point or under a stiff board under the jacking point to lift it a fraction. If the bump stops are non-existent there is a slight chance the pistons have moved too far and are covering the port in the cylinder body. Or the rollbar can move side to side too much if the bushes are worn and the HC valve is binding up because of too much lateral pressure from the linkage.
    16,426
    It's almost always an empty reseviour in my experiance. Have a look under the car, I bet all the LHM you added has leaked back out (somewhere). The more obvious telltale is the pump usually gets noisy and rattly as it runs out of fluid.
    It's unlikely I've found for the height corrector to get stuck on low unless you have been messing with the linkages or height control lever ( I've found they usually lift to normal ride height, but will not adjust height when the height corrector is seized, as the linkages are not capable of moving the height corrector when it's sludged up internally).
    9,777
    Or the pump has an internal leak due to a split body. I do recall a Special that wouldn't rise at the front unless you held the revs up for 30 seconds. The pump body had split.
    8,185
    The other likely possibility is a crack/split in the rubber hose from reservoir to pump - only takes the slightest split (you may not see it) to suck air.
    forumnoreason likes this.
    08 C5 X7 HDi very Noir
    3,581
    Thank you all for the advice and input, and I am trying to digest it all! Went back to it today.Not sure what i did first, but now the rear will not rise either! I did run the engine, and played with the lever a lot. Then I took the 12 mm spanner to the bleed nut, opened it with the engine going, there was this hissing sound. When it stopped, I closed her up.the car still sitting on the floor. Now, how do I know I have enough LHM in the system? She is not making that cloggedeglog sound anymore. I stuck a long screw driver into the LHM tank, and there is an inch of fluid there. Now what? Sad Bertie.
    3,581
    By the way, there appears to be no leaks!
    Jul 2004
    Castlemaine Area
    466
    I think I'd want more like 3 to 4 inches - - at least.
    John
    UFO likes this.
    8,185
    Bertie, Bertie, Bertie. . .
    You need to top up the LHM !!
    You check the level (without a screwdriver) by using the front clear sight tube. As your car is sitting on bump stops (Lowest) the level should be close to top rib on the tank, around 80mm from the top. Once topped up you check the level with the car on the highest setting, LHM should sit between the Mini/Max mark at the sight tube.
    Once you have corrected the LHM level, let's see it the car rises. . . if so, check each corner with the car at normal ride height, it should be soft and compliant. If any corner is stiff you would suspect a ruptured sphere membrane, this would account for some fluid loss and the hissing you heard.
    Aug 2011
    407
    By my count, six possible causes and solutions so far! From personal experience, I can add a seventh - blocked outlet tube from the height corrector. Being a Citroen, any or all of them are perfectly viable...
    Citroën Tragic UFO's Avatar
    9,721
    Low fluid, pump sucking air. Open your wallet Bert. By the sounds of it you need at least two litres of LHM.
    9,721
    Quote Originally Posted by Citroenfan View Post
    It is essentially the same in a RHD D as the RHD adaption for the height lever is that the lever is on the right but a rod transverses the front of the seat mount "box" and attaches to the normal mechanism on the left.
    Apr 2013
    Essendon
    660
    Come on guys, how about telling him he got a lemon and he should get rid of it!
    JAJEA
    3,581
    Dear mister Greenblood, the reason I used a screwdriver, no harm in that, i might ad, is .that it wasn't showing anything on the tube. The manual will tell you to check the level when the car is in high, which I couldnt do. I could be forgiven for thinking all the fluid was elsewhere in the car.
    3,581
    Quote Originally Posted by JAJEA View Post
    JAJEA
    This is no lemon.
    3,581
    I know the sound of a pump sucking air, and it is not doing it.
    3,581
    Quote Originally Posted by gilberthenry View Post
    John
    Yes, I am sure there are few guys out there who wish for that!
