D Super pulling to left
Results 1 to 25 of 34
Like Tree4Likes
Thread: D Super pulling to left
    Kapunda
    457
    Default D Super pulling to left
    After a couple of years in the Shed the Super is now undergoing road tests'.As I havn,t yet had time to recon the power steering I am presently using a non powered steering rack,it seems to be fine for country roads!The only issue at present is that it is pulling to the left a bit.I checked the toe after changing the rack and that's OK.Tires are good ,no conicity.Looking for ideas.
    Woody
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,070
    Have you checked the caster angles?
    Cheers Gerry
    Kapunda
    457
    Thanks Gerry.Have checked the Camber angles but not the Caster,that is a bit more challenging,and what could I do about it if it is wrong.(Actually I have heard of someone bending a suspension arm with a long piece of 2in tubing.) I,m hoping for something simpler.
    Woody
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    I think you can adjust the upper or lower arm backwards or forwards.
    Roger
    Apr 2014
    Phoenix, Arizona USA
    676
    Pulling all the time or just under braking? If it pulls under braking is possibly a seized brake caliper on the side that it pulls away from, i.e. it will pull to the side of the brake that is working.
    John T.
    Kapunda
    457
    Sadly there is no adjustment on the Susp Arms Roger.It pulls to the Right all the time It is fine if I drive on the wrong side of the road?
    Woody
    Oct 2003
    canberra
    851
    One protective D, just trying to protect you from those right wingers out there Brian!!
    3,070
    Quote Originally Posted by brian woodcock View Post
    Woody
    Operation ID-410-3 of the ID 19 manual. As far as I know the axles are the same in regards to the bearing set up for the upper and lower arm.
    Cheers Gerry
    16,426
    Quote Originally Posted by citroenthusiast View Post
    DS's don't do that I drove home a DS23 that had completely worn through on of the front brake rotors. Even with only one front brake working, you could lock the one front wheel under braking.... and the car wouldn't pull to the side. Infact you could take your hands off the steering wheel and stand on the brake button and it would just lock one front wheel and track dead straight.
    They really are a remarkable car
    I think I'd be looking or a bent steering arm ... or a mixture of powered/non powered steering rods. I had a GS a few years back that would always pull to the side. I eventually decided it's front passenger side lower suspension arm must have been bent. I ruled everything else out!
    10,815
    Thanks Gerry.Have checked the Camber angles but not the Caster,that is a bit more challenging,and what could I do about it if it is wrong.(Actually I have heard of someone bending a suspension arm with a long piece of 2in tubing.) I,m hoping for something simpler. Woody
    Lucien Bianchi was observed sorting this with a very big hammer in SA in 1967, I have on good authority...
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Apr 2014
    676
    A worn through disk might give different behavior than a seized caliper. I had the opposite experience with my '67DS. It pulled badly to the side when I stepped on the brakes but I couldn't find any looseness in the suspension or steering linkage. Daffy diagnosed it as a seized brake caliper and rebuilt the calipers. All is well now.
    That being said, Brian, did you check the condition of the rubber bushings where the track rods attach to the trolley at the middle of the rack?
    John T.
    16,426
    Now that is interesting. It wasn't one of the rear brakes that was seized
    9,777
    You shim the bottom arms to alter the caster. There is an adjusting washer or ring that sits behind the front bottom bearing cup. So, it's not really something you can adjust easily when you consider the procedure for changing the bearing cups. Not a simple task as in many other cars. Note any shims if you go into the suspension arm bearings. If you've taken the arms out, changed the bearings and omitted the adjusting ring, the bottom arm will be too far back and the caster angle will be way out.
    If the car didn't do this when it was left in the shed, it's probably not the caster angle or a bent arm, but more likely something done recently or a dragging brake problem. What do you smell after a drive? Is one caliper / handbrake hotter than the other???
    Apr 2014
    676
    No, it was definitely the front. Admittedly my story is anecdotal, however, isn't it also true that the "true" center point steering went away with the 5-main bearing engine?
    John T.
    16,426
    I can't see how the geometry changed The car in question that I drove iwth only one front brake was a 1974 (1975 model year I think) DS23ie 5spd pallas. One of the very last cars.
    shane L.
    3,070
    Absolutely not! The design of the ball joints changed as did the hub but the pivot line remained on centre with the ball joints and the centre of the contact patch of the tyres.
    Cheers Gerry
    Kapunda
    457
    I,m with Shane on this one,I,ve come across many D,s where the RHS Disc has been well lubricated (for well known reasons) and yet the car would not pull to the left on braking.I never drove the car before it went into the shed,I dragged it in.
    Woody
    3,070
    You didn't hook the tow chains to the suspension arms did you?
    Cheers Gerry
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    163
    I thought that was the correct way to do it? Please correct me if I am wrong as I have done this once and have another trip to make on the back of a flatdeck in a couple of weeks!
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
    16,426
    Quote Originally Posted by Vincenzo View Post
    I can't see why that would hurt the arms if the car is free rolling. They are very solid lumps of metal! It's how I move any and every DS too ... as there is nowhere else to tie too that is strong enough
    Vincenzo likes this.
    Apr 2014
    676
    Thanks for setting me straight on that. As to the original question, Brian, did you check the simple things like the centering cam?
    John T.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    543
    Try swapping the tyres around and see if it changes. Tyres will go off sitting in a shed.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    3,070
    Depends on where the force is applied. A triangulated pull on both arms with chain and hooks is OK because the chain pulls in close to the large diameter end of the arm. Pulling with only one chain and hook allows the attachment to slide out to the hub end. --------BAD
    Cheers Gerry
    Kapunda
    457
    Thanks for your helpful suggestions John,however as I am temporally using a non powered rack (Which I have reconditioned) I have removed the steering cam.
    Woody
    Kapunda
    457
    [QUOTE=David S;1490132]You shim the bottom arms to alter the caster. There is an adjusting washer or ring that sits behind the front bottom bearing cup. So, it's not really something you can adjust easily when you consider the procedure for changing the bearing cups. Not a simple task as in many other cars. Note any shims if you go into the suspension arm bearings. If you've taken the arms out, changed the bearings and omitted the adjusting ring, the bottom arm will be too far back and the caster angle will be way out.
    I ve just dismantled a front 1/2 axle,no sign of any shims or spacers.Having perused the manuals I believe this facility was deleted on later cars
    Woody
