Something missing TA96 not connected?
Results 1 to 7 of 7
    Aug 2016
    Sunshine Coast, QLD
    913
    Default Something missing TA96 not connected?
    TA96 oil pressure sensor on rear of auto box...mine
    Wiring harness has no wires to last connector.
    Should I run a new one as have one from the petrol auto?
    Sent from my GT-I9195T using aussiefrogs mobile app
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,952
    Is there evidence of wires having been in the connector left on the ECU? If so I think that would be a good idea to remake the loom.
    Cheers, Ken
    Aug 2016
    Sunshine Coast, QLD
    913
    well there is no wiring on the other side of the ECU plug, so easy answer not required on my C5. crossing finger,s now for add oil and reconnect gear cable and see if any difference.
    19,171
    It seems to me it time to check out some manufacturer data, ie wiring diagrams.
    Or check out another car with the same trans and control module.
    Newcastle
    2,660
    Hi Dimi,
    A quick google said that TA96 is a map sensor. Manifold air pressure sensor for a petrol engine. Not used as such on a diesel. Ignore !
    Jaahn
    Aug 2016
    Sunshine Coast, QLD
    913
    great John, lunch break...I have to keep remembering the previous owner was driving this car before towing it in to get traded, so no dodgy work around to get it going and the dealer did nothing for 6 months before selling it to me, update in the afternoon on the original post so it can be tracked
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by dimistyle View Post
    Not needed. Its a thermostat to control the flow through the heat exchanger. No wiring? then use the module without wires.
    Cheers and luck.
