Ds21 front speaker
Results 1 to 9 of 9
  • 1 Post By badabec
Thread: Ds21 front speaker
    Mar 2003
    356
    Icon5 Ds21 front speaker
    My original speaker is showing some damage and the sound is really Low-Fi. I would like to change it, while retaining the original old push-button radio. I don't expect much difference in sound quality but it should be an easy swap?
    My questions are - How do I remove the plastic cover and what is the maximum size speaker which will fit?
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Kapunda
    462
    Hi Don
    The plastic cover just needs a bit of gentle leverage with a screwdriver unless someone has used some adhesive,I usually have trouble keeping them on!
    Woody
    Jun 2015
    Ashburton
    205
    Quote Originally Posted by tresbon2 View Post
    Don
    I managed to get 2 of those smaller speakers into the space. Got them at jb. Can't recall size but if you ask for a look at their range under the standard size they will show you. It is tight but it works.
    Mar 2003
    356
    Quick update - I found that the grille came off easily and that the speaker cone was totally detached from the edges. I also found that there was no way I could fit my new 6 inch x4 inch speaker in, due to the large diameter magnet and the vicinity of the mirror and bracket. I'm not ready to take the dashboard off yet, but when I do I may be able to get some power to the interior lights also. Thanks for the responses - I will check out the JB hi -fi speakers which I expect will be 4 inch diameter.
    Don
    Feb 2012
    Ongar / England
    843
    Mort Subite likes this.
    Mar 2003
    356
    Quote Originally Posted by badabec View Post
    Thanks, but not at that price (approx.90euros inc delivery)
    I will devise a cheaper option.
    Don
    Feb 2012
    Ongar / England
    843
    Hello, how about
    DAI CHI DC46 30 6" X 4" Inch 30 Watts 4 OHM Dual Cone Replacement Speaker | eBay
    I'm hoping to squeeze a Retrosound 7x5 dual voice coil into my dash. Their speakers are quite shallow.
    Mar 2003
    356
    Hello, how about
    It looks identical to my brand 'X' 6x4, which I could not easily fit into space.
    Don
    Apr 2014
    Phoenix, Arizona USA
    681
    DS front speaker is oval 3 x 7 inch the mounting holes are on a rectangular pattern about 2-1/4 x 6, which is an oddball size. I ended up making a backer out of a piece of hardboard (masoninte) the size of the old speaker painted black. I then cut a circular hole in the backer and installed a round high efficiency (I think it was 1.5 inch) micro tweeter in the space. Hardly noticeable and the woofer on the back shelf works pretty well with the tweeter under the mirror.....
    John T.
