DS Ignition Switch
Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By forumnoreason
  • 1 Post By marc61
  • 1 Post By badabec
Thread: DS Ignition Switch
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Default DS Ignition Switch
    Hello gents
    A couple of weeks ago I acquired a 21EFi saloon from a barn in France. I'm presently working through numerous issues, trying to get it back on the road soon. Its only done 93000km and is in good shape apart from the paintwork. It's been stored for at least 12 years.
    The thing that has stumped me is the ignition switch. The ignition key is broken, most of it remains in the switch, so today I removed the dashboard and set about removing the switch. One of the cone shaped nuts is in a recess and very difficult to get at so I'm getting nowhere at present. Have tried pliers and hammering a socket onto it but no joy. Anyway I'm thinking even if I do get it out the ignition switch will probably need replacing as no doubt the key broke for a good reason. The price of DS ignition switches is way too ridiculous for me so I am looking for another solution.
    I know the brown and white wires leaving the ignition switch go to the 12V feed and the starter solenoid, so fitting a starter button is an easy option. But the rest of the wires go to a white connector. I'm thinking these are for the circuits that go live once the ignition is switched on (coil supply, ECU supply, indicators, heater fan etc). Is that correct? If so a single switch could be fitted to switch all of these circuits on?
    When I look at the white connector that's on the car (not on the ignition switch) it's got two rows of 3 terminals:
    Top row: yellow wire green marker; black wire no marker; black wire red marker
    Bottom row: yellow wire violet marker; yellow wire no marker; black wire blue marker
    Does each one of these need a +12V feed via a switch? I'm thinking this could be straightforward but am I missing something?
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    San Diego, California, USA
    3,533
    Quote Originally Posted by marc61 View Post
    Hello gents
    Marc
    At the risk of something, I'm not sure what, go to my landmark treatise here. I was just finishing it up for Bushyben when you posted. Of course, any questions, you know where to find me.
    It should currently be the last post. (#22)
    Jul 2013
    Stamford, UK
    331
    Thanks very much HRE.
    There are 3 inputs and 3 outputs at that white connector, so it's just a case of having switches to connect the right ones. The only difference on my car from what you describe below is that I've got 3 black wires and 3 yellow wires. I've not got a black wire green sleeve, but a yellow wire green sleeve instead - guess it's the same.
    Marc
    There will be 3 (hydraulic shift) or 4 (manual shift) pair of wires on that switch. 3 (4) inputs and 3 (4) outputs. Those inputs and outputs are:
    Black wire, red sleeve: battery in for coil
    Black wire, blue sleeve: battery out to coil
    Black wire, green sleeve: in from "red" fuse
    Yellow wire, mauve sleeve: fused ignition output to instrument cluster, heater fan, wiper motor, wiper switch
    Black wire, no sleeve: in from "green" fuse
    Yellow wire, no sleeve: fused ignition output to regulator at "BOB", brake light switch, turn signal switch, and rear defroster if you have it.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    3,533
    Thanks for spotting that. I've made the appropriate correction over at that page. You're right, that is supposed to be a yellow wire with a green sleeve.
    Damnit, I'm supposed to be more professional than that.......
    Ici.
    2,560
    AF should have a gold coin donation box for Bill! I'd like to buy you a stiff drink or ten one day mate.
    daffyduck likes this.
    3,533
    The sentiment is greatly appreciated. If I ever get to make it down-under........
    Jul 2013
    Stamford, UK
    331
    No worries, appreciate your determination to get things right!
    Just to complete the story, today I cut off the terminals on the back of the ignition switch, pulled back the rubber covers and soldered female bayonet connectors to the 3 supply wires (red, black, green). This enabled the white connector to be used and 3 normal switches on the dash to be connected. Now with a starter button I can get it running!
    A bit crude I know. But hey it works!
    Marc
    Vincenzo likes this.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    435
    RFID immobiliser, some £35 on Amazon?
    3,533
    I like the thought of an RFID setup. Not only does it make your car considerably harder to steal, it's hella convenient when installed with that stop/start button (you don't have to install that). Installing that correctly in a D would be very difficult to find and defeat.
    Jul 2013
    Stamford, UK
    331
    I fitted a simple black start button - undid the cigarette lighter and fitted it into the hole, neat and simple. But I now need to fit an immobiliser and you've got me thinking.
    A simple immobiliser would do I guess, there's some very cheap ones from China on eBay, might be worth a try. But I'm also thinking because it's an EFI car wouldnt it be neat to have an immobiliser with a remote that's sophisticated enough to immobilise/activate but also able to do a remote start. Press one code to activate then another to operate the solenoid and start the car - get the suspension up by the time you reach the vehicle. Just need to remember to leave it in neutral! Maybe something like this The safe Immobiliser for every Vehicle!Simple Programming and Installation
    There's probably some law against doing that but it'd be handy for a Citroen!
    Marc
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Feb 2012
    Ongar / England
    832
    What are going to do with all those 10 seconds you'll save?
    GreenBlood likes this.
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    161
    I did something almost exactly the same a couple of years ago. The ignition-barrel et al was removed and replaced with a gaudy cheap red button from Jaycar... and I made a switch box that duplicated the 6 pin connections exactly, using 3 switches to bridge. The wires were fed through the bottom bolster and the switch box was velcro'd under the steering wheel. When my new right-hand drive ignition switch finally arrived I had grown to like the temporary arrangement and didn't want to do the proper fixup. Anyone want to buy a brand new rhd late D ignition switch?
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    I kind of like this idea too. That is one thing that is nice about the Prius, keyless entry and start. As I suspected it is not that hard to implement even if not to the Toyota standard. e.g. You can only operate the lock you are standing next too when unlocking the car, if you stand next to the drivers door and note by the interior lights that it can 'see' the key somebody standing at the passenger door can not open that door. Obviously it has multiple antennas around the car so it knows exactly where the key is. Possible issues to resolve:
    1. Remote entry, possible on a CX but more difficult on a D I would think.
    2. D-Jetronic and L-Jetronic start the pump on starter cranking. Not so LE-Jetronic on the CX 2500 which runs the pump for 5 secs on ignition on. Should not be too hard to duplicate though.
    3 What are we doing with steering locking. At present we have to put the key in and turn to disengage. Do we just leave the key in to hold the lock off.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Jul 2013
    Stamford, UK
    331
    I took the ignition lock ring off the steering column, it's just held on by two Allen keys. Having had a broken key, a duff ignition switch and one nut that holds it in place that I simply can't undo, I didn't want there to be any chance that the steering would lock up. Like Vincenzo I'm just just happy to have switches in the car to enable it to be started right now
    There's only circuit that provides power to the ECU, fuel pump and ignition so press that switch and you get 1-2s of fuel pump activity, then press the starter button and the engine starts. So conceptually a two button remote could do that.
    Meanwhile I've just replaced the rubber fuel hoses at the pump. Discovered a slight leak on the pressure side, then when taking the old ones off they just broke in half!
    Marc
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Jul 2013
    Stamford, UK
    331
    Could someone give me a steer on the earlier ignition switches fitted to the D, before the large key ignition switch was introduced. Did they all use a small key and a starter button? Did the small key switch have connections on the back to switch on the 3 circuits (coil, wipers, indicators)?
    Marc
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2016
    Bedford, UK
    705
    Mines in bits so i can't go and check for you. Someone like Hotrodelectric will tell you if I am wrong, but here goes: the ignition switch used before yours (so I'm talking about the mid-period cars) was coupled with either a starter button (if a manual car) or a pair of contacts within the steering cluster and operated by the gear (if a bvh car). The starter button (or contacts in the dash) serve to operate the starter motor and inasmuch work independently of the rest of the ignition circuit. You can press that button or move the gearstick and the starter will do it's job and turn the engine over - but you'll have no spark. In both cases (manual and bvh) the ignition key unit/ switch has four terminals on the back. Putting in the key and turning connects those terminals as two pairs (i.e. two circuits are completed). One of those circuits is to the coil. The other circuits, when closed, powers up the dash warning lights and gauges, the indicators and the fresh air blower motor switch. I don't think the wipers are dependent on having the ignition switched on.
    Hope this helps.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Hope this helps.
    Same switching system as used in my11BL! Only I have to pull on a cable to operate the starter motor!
    Cheers Gerry
    Jul 2013
    Stamford, UK
    331
    Hope this helps.
    Thanks for explaining that Budge. Do you know if the 4 terminals on the back of the switch are male bayonets?
    Marc
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2016
    Bedford, UK
    705
    Do you mean flat spade ends? Anyway they are neither bayonet nor spade. They are male bullet ends. You will be able to find an image of a repro on the sites of the online sellers
