xantia power steering belt broken
Results 1 to 2 of 2
    Nov 2014
    ashburton nz
    25
    Default xantia power steering belt broken
    hi again guys
    just had belt break on my 2001 hdi xantia ;loss of power steering ;brakes etc
    does any one know what size belt to use on this car as i need to bypass
    air con unit ;do not have old belt to get size off ie how to size belts
    regards kevie
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    624
    use a peice of string to get the length then count the grooves in the width, belt sizes work in 6pk for grooves wide and the the length in millimeters so a 2.0hdi 8 valve has a 6pk1750 so six grooves wide 1750mm long
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
