C3 low beam bulb blows twice
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By COL
  • 2 Post By Demannu
Thread: C3 low beam bulb blows twice
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    Default C3 low beam bulb blows twice
    Hi All
    My daughters C3 had a low beam h/light bulb go. It went again after being replaced...
    Suggestions on why? Is there an electrical load distributer that balances out power to the bulbs that may have failed?
    thx CC
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    Quote Originally Posted by ccc View Post
    Hi All
    thx CC
    I would just say that you are unlucky thats all. You most likely got a dud bulb.
    Put another one in and see how it goes
    Mort Subite likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    might try to put a multimeter on it and compare the L & R h/lights?
    Dec 2002
    2,537
    Was it a cheap Supercheap auto globe or similar? I had one of them last less than 15 minutes once. I now stick with more reputable brand names.
    Mort Subite and driven like this.
    Scotty
    Melbourne - Dandenong Ranges
    1999 Peugeot 406 Coupť - 'Chloe' - 5 speed manual
    2014 Peugeot RCZ - 'Remy'
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    A Wurth bulb installed by a reliable french mechanic
    19,103
    Check the system voltage and consider the potential for vibration.
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,046
    Toyotas are reknown for blowing head light bulbs.
    DS 21
    C4 HDI
    Piaggio Fly 125
    19,103
    Quote Originally Posted by arunine View Post
    So are C3s it would seem. It would seem more logical to find the cause.
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    spoke to an old french Mechanic : ) was advised the bulb going was common in the C3 and probbly symptomatic of the alternater and/or its regulator being on the way out.. causing peak voltage spikes..
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    The original H7 low beam lights on my C5X7 lasted quite a few years. When they eventually failed, I seemed to go through quite a few 2 paks from Supercheap quite quickly. I did find that I had managed to catch the light deflection ring inside one headlight and bent it a bit so it was touching the bulb. I guess that didn't help bulb life and luckily I was able to straighten it up without breaking anything. Finally I bought some standard Philips bulbs on ebay at a much more reasonable price and now bulb life seems to have stabilised and be back to normal. EAI seems to have some less expensive bulbs available.
    Cheers, Ken
    1000+ Posts N5GTi6's Avatar
    1,096
    As they say - the silliest thing is the thing that is never mentioned - make sure there are no skin contacts on the bulb when replacing it - the oil from your skin can destroy a bulb pretty quickly.
    I've just replaced a H7 bulb in my daughters C3 as well - drivers side was nice and easy - took all of 2 mins. Passenger side however looks like you either need go-gadget hands to get in there - or remove the battery....
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
