xantia light bulbs
Results 1 to 7 of 7
    Nov 2014
    ashburton nz
    25
    Default xantia light bulbs
    hi guys
    been searching web sites trying to find imfo on changing fog light bulb on hdi xantia ;
    been out to car removed battery;air filter battery box ;drove me to drink
    any easy way to get to bulb dont have manual.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,927
    KEVIE,
    Is your Xantia a Series 1 or Series 2? What year was it built? Does HDI imply a Series 2?
    My owner manual for my Series 2 says to take the car to the Citroen Dealer to replace a Fog Light Bulb - big help. I have replaced a fog lamp on my Series 2 and I had to partially undo the front bumper and pull it forwards a bit so I could get my arm in under the bumper to get to the locating bolts.
    My Series 1 wagon with owners manual is living with my son at present so I can't check that manual at the moment.
    Haynes has some instructions for extracting the fog lamp out through the bumper but I think that will only work for a Series 1.
    I might be able to help more with scans from Haynes or Owners Manuals once I know what series you have.
    Cheers, Ken
    Don't remind me!
    16,609
    HDi will be a facelift car. You can pull down the wheelarch liner a bit from memory, and get the bulb from underneath.
    Aligning the foglamps is best done with headlamps removed, you access the alignment screws from above.
    Nov 2014
    ashburton nz
    25
    thanks guys xantia is 2001 hdi not sure if its a series 1 or two but will try what you suggest in
    the morning thanks again.
    Oct 2003
    Hampton Park
    523
    Quote Originally Posted by KEVIE View Post
    Series 1 HDI I didn't know that?
    Armidale
    2,346
    Series I /II changeover was in 1998, so a 2001 Xantia is definitely Series II. You are right Sherman - there was never a Series I HDi.
    Nov 2014
    ashburton nz
    25
    thanks guys
    so car is series 2 will above imformation work for series 2 cant work on car till weekend so any imfo
    would help regards kevie
