Ds driveshafts- renew or reco //
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By gerrypro
  • 2 Post By GreenBlood
Thread: Ds driveshafts- renew or reco //
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    367
    Default Ds driveshafts- renew or reco //
    the next item on the list is to rectify the clicking driveshaft- has anyone recently executed this job and are the new outer CV units from OS the way to proceed.
    anyones experience will be appreciated and also may help others considering the same.
    thanks
    Mar 2011
    Broom
    816
    I have heard about this clicking, although I have never experienced it myself. I would love to know exactly what the clicking is. Having removed a few drive shafts, I have seen that the grease in the tri axe housing can become a dry. Is it the bearings on the spider giving way? Either way, they are pretty easy to remove and check, if it is the main coupling then I guess a replacement is the only option. But it may not be that bad.
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    I've just put one on the left as the clicking was getting progressively worse, onto clunking etc. It's a neat little unit. Weighs much less, the cv pivot is completely within the steering pivot and looks beautifully made. I wouldn't bother re-building. It cost me about 30 Euro less than quoted too.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Ici.
    2,560
    EU cars prefer no grease, Australian cars need grease.
    Don't remind me!
    16,609
    Ooh-ooh-ooh?
    Mar 2011
    Broom
    816
    yeah, much wiser for that.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Quote Originally Posted by mberry View Post
    In a Traction the clicking is caused by wear in the ball and spigot joint that centralises the Double Hookes Joint and allows angular deflection of the stub axle from the drive shaft. The layout of a D drive shaft is identical in concept at the outer end of the system however the crosses are much larger and heavier and last for a very long time. Strangely the Ball and Spigot Joint is the same dimension as in a traction. When it gets sloppy it sets up a weird oscillation in the joint causing severe end loadings on the journals of the crosses. As these parts wear, just as in a traction they move sharply back and forth producing the characteristic click!
    mberry likes this.
    Cheers Gerry
    Kapunda
    456
    On the DS the clicking is usually caused by wear in the Triax.,If you clean up the triax the wear can be seen where the balls drive the shaft in its normal position.So far (in 40 years) I,ve replaced about 6 triaxes and no CV joints.
    Woody
    3,067
    Yes, the triaxe will wear just like any mechanical component. Nobody has yet mentioned whether or not the clicking is on lock or straight ahead driving!
    Cheers Gerry
    8,184
    Icon3
    This from Citroen Classics UK
    https://citroenclassics.wordpress.co.../drive-shafts/
    gerrypro and Vincenzo like this.
    08 C5 X7 HDi very Noir
    3,067
    I like this solution. Almost as good as a CX!!!!!!
    Cheers Gerry
