Engine diagnostics.
    St Helens Tasie
    603
    Default Engine diagnostics.
    Anyone have knowledge re. the way the engine diagnostic devices work. My C5 x7 has just had one plugged in and there are many codes showing up on the dealers device. Are all these codes an accumulation of the past 6 years of things that may have taken place in the engine management computer. Can they be deleted so that only the relevant ones remain? I have no wish for the mechanics to be chasing codes that are not relevant to the symptoms the car displays. ( Turbo and cruise cuts out after a few minuter driving, drives OK but without much grunt and cruise on pause). Allan.
    8,756
    They accumulate, so I'd take note and delete. Current problem codes will come back quickly.
    16,416
    I'm surprised they didn't just clear them ... then check again in say a weeks time to get any current errors
    Don't remind me!
    16,609
    You can sort them in the fault log, in chronological order or frequency of occurrence.
    The fault log can be cleared.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,926
    They are stored as permanent or temporary faults. You only need to chase down the permanent faults. Once you try to clear faults, Diagbox asks you to record a service event so you have to enter a kilometer reading and the attempt gets recorded in the log I suppose. It only seems to allow the faults to be cleared on one ECU at a time.
    Well that is my limited experience so far.
    Cheers, Ken
    St Helens Tasie
    603
    Thanks all. This is what I hoped will happen. Allan
