2004 C5 HDI Estate Gearbox
Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By shanadoo
  • 1 Post By addo
Thread: 2004 C5 HDI Estate Gearbox
    Apr 2015
    2
    Default 2004 C5 HDI Estate Gearbox
    Hi all, hoping to get some guidance on this.
    The C5 has around 170,000 km on the clock. Have had new solenoids put in the gearbox late last year. Last night while driving, it wouldn't drive forward from a stop sign. Engine was revving but car wouldn't move. It would reverse ok, so I tried forward again. It moved, but wouldn't go up a hill. Tried putting it in the 2nd start mode ( the snowflake) and that got me going ( sort of) and limped home and parked. The gearbox has been slipping for the last couple of months and giving the "slip error" on the console and locking in 3rd gear which needs turning off the engine to reset.
    Last service at Euroserve Brisbane, was told that the gearbox was on the way out and was quoted around $6000 would fix it. Anyone have any thoughts on whats broken and if there is any way of getting it back on the road for a lot less than that? I.E. 2nd hand gearbox??
    Gerry
    Feb 2011
    brisbane Au
    927
    My guess is you've got a broken F3 brake band, usually an expensive repair.
    Send a PM to GarethB, he had Al4 box for sale cheap.
    addo and garethb like this.
    Don't remind me!
    16,609
    Is that F flat diminished?
    The AL4 Blues needs penning.
    shanadoo likes this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Hi Gerry,
    Sounds like it is too late to add some Lucas Transmission Fix to your box. You will need access to a box that comes from a similar car and should reuse the ECU from your existing car. Even then it will most likely require an electronic interrogation to reinitialise settings.
    Perhaps contact John Walton at DS Motors and see if he can source you a 2nd hand box through his contacts down south.
    Good Luck
    Cheers, Ken
    Nov 2013
    Gold Coast
    153
    Quote Originally Posted by shanadoo View Post
    Thanks Tony, yes, the AL4 is sitting in the garage ready to move on. PM me if you're interested Gerry.
    Feb 2011
    brisbane Au
    927
    It's advisable to use your existing trans ecu. The Al4 boxes in C5 are mainly plug and play. So if your engine is the same as garethB's drop it straight in, if not, just use your own converter. I've had a couple of second hand boxes fitted using the original ecu and never had to reinitialize. After all the ecu controls everything.
    A word after completion of repairs, the factory says it's imperative but I've always taken them for a good drive around the suburbs anyway, making the box use plenty of gear changes under as many different situations as I can find. The ecu will learn the driving style and make driving that much better.
    Apr 2015
    2
    Hi all, thanks so much for the replies. I will PM Gareth and see what's what. Cheers.
