More SM problems
Results 1 to 7 of 7
  • 1 Post By Ken W
Thread: More SM problems
    Kapunda
    456
    Default More SM problems
    I have an SM here with a bent upper wishbone (Radius arm?) (I mean bent more than it should be) Please can someone tell me if it is the same as one off a DS ,of which I have heaps.
    Woody
    8,184
    Quote Originally Posted by brian woodcock View Post
    Woody
    Parts manual for the SM and D show the same part number(s). . . both upper and lower should be interchangeable between models.
    08 C5 X7 HDi very Noir
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,926
    Your not repairing one that got bent on the back of a tow truck in Victoria are you?
    SM Part no for Gauche is 5 406 667 V
    SM Part no is Droit is 5 406 668 F
    Do these match DS part numbers? If not perhaps Peter McLeod could help.
    Cheers, Ken
    Last edited by Ken W; 9th July 2016 at 07:48 PM. Reason: Correction to part numbers
    8,184
    Icon11
    Quote Originally Posted by Ken W View Post
    SM Part no for Gauche is 5 410 219 D
    SM Part no is Droit is 5 410 218 T
    Cheers, Ken
    I might be leading Brian up a garden path Ken, am I looking at the correct part
    SM
    DS
    Attached Thumbnails Attached Thumbnails More SM problems-ds-upper-lower-arm.jpg   More SM problems-sm-lower-upper-arm.jpg   More SM problems-ds-upper-lower-arm-image.jpg
    North Brisbane
    1,926
    Whoops, I copied the part numbers for item 5 not item 4 as I had intended. I should be working on my bigger screen.
    I have also realised that you cannot rely on a copy and paste from an PDF document.
    Your SM Parts pdf looks a lot clearer then mine.
    Well done Chris.
    Cheers, Ken
    GreenBlood likes this.
    Symar/ca/usa
    607
    Woody
    Brian,
    As others have said - exact same part. On the SM they are just mounted 'backwards' compared to a D . Half shafts are the same also, the only difference being that on the SM both sides are of equal length.
    Steve
    Kapunda
    456
    Thanks heaps Guys.
    Woody
