Cx 25gti auto lumpy tickover
Like Tree5Likes
  • 3 Post By UFO
  • 1 Post By johnmowcop
  • 1 Post By Bruce Llewellyn
Thread: Cx 25gti auto lumpy tickover
    Mar 2015
    United Kingdom
    13
    Default Cx 25gti auto lumpy tickover
    Help anyone please.
    Tickover at 1000rpm lumpy, any slower it will cut out. When reverse selected it cuts out unless I keep revs on with right foot on throttle and left on brake.
    Recently had trouble with the big blue solenoid, cleaned connections now it starts ok (thanks to this forum for that). Not sure if this is connected to the above.
    Regards
    JohnT
    CitroŽn Tragic UFO's Avatar
    9,721
    It will be a leak in the engine air intake. Look first at the concertina hose from the air filter to the intake manifold. It may have a radial crack in it. Can usually be easily repaired with wide duct type tape (eg uber wide electrical tape) OR the jubilee clamp where that hose connects to the intake has become loose.
    When you change into reverse the engine moves backwards on the mounts and that's just enough to pull the hose a little bit and the manifold gets too much air and the engine stalls.
    Also take the opportunity to look at your engine mounts as the engine may be flopping around on worn upper (dogbone) or lower mount.
    JohnW, Greg C and johnmowcop like this.
    Mar 2015
    United Kingdom
    13
    Thank's UFO.
    Checked this and found that when messing with the blue solenoid I had disconnected the air hose to the inlet manifold and not reconnected it properly. Did'nt realise sucking air at that point would cause the problem, Why is that anyone know?
    JohnT
    UFO likes this.
    Oct 2011
    Toowoomba
    647
    Yes,
    The airflow sensor is upstream of the hose, and a leak means the engine is getting more air than the computer thinks it is so doesn't give sufficient fuel.
    Bruce.
    UFO likes this.
    Mar 2015
    United Kingdom
    13
    Thanks' for the response Bruce.
