Tow bar for C5
Results 1 to 13 of 13
Thread: Tow bar for C5
    May 2014
    Margaret River Western Australia
    81
    Default Tow bar for C5
    Sadly, I need to spoil the rear end of my 20010/11 C5 with a towbar. Can anyone provide some advice about the best way of achieving a neat system, probably involving a removable tongue. Witter in the UK make some neat units, I think. Are they available/ certified for Australia?
    8,763
    Hayman Reese - 03031RLW - haymanreese
    Australian Design Rules differ from British, and you will need to allow for the chain setup and the maker's approval/load stamp which shows the Police and Rego inspectors that it complies.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,927
    Are you OK to stay below the ball weight rating of 57 kg?
    You will need to fit a trailer lights relay system so that you do not add extra load the car's rear lights harness as well.
    Cheers, Ken
    Fellow Frogger! Dijon16's Avatar
    Jan 2005
    371
    Many previous posts on exactly the same subject, have you done a scan?
    FWIW, my 2010 C5 had one already when I got it, the 2inch tube tube with locking pin. Has what looks like factory (or dealer) sticker for it in the driver's door opening, but it still does not disable the rear sensors when reversing.
    Manual says that download is limited to 57kg.
    May 2014
    81
    Thanks everyone. Very useful advice. I suppose I should check with the Citroen agents in Perth and see what they recommend.
    8,763
    You may need a mortgage with that method.
    The Australian Hayman Reese kits come with the electronic box of tricks needed with the car wiring bus. Some brands may not disable the rear parking sensors, but a few beeps only when reversing a trailer isn't so bad. Australian detachable tow hitches need a small notch removed from the plastic bumper underside.
    Fellow Frogger! laurie_lewis's Avatar
    Armidale, NSW
    234
    Allen I got one from Brisbane, delivered, at a pretty reasonable cost. European type with max ball weight of 75 kg. When the goose neck comes off and the electrical plug is swung up behind the rear tray it does not spoil the lines very much at all.
    Sent from my iPhone using aussiefrogs mobile app
    Armidale, NSW
    234
    Showing $707 so gone up a bit.
    http://www.towbarsaustralia.com.au/towbar-kits/c5-0
    Oct 2003
    Hampton Park
    523
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
    If your trailer has led lamps there is no need for relays
    I took them off my D9 406 and no probs
    May 2014
    81
    My trailer is so old I have to light candles. Maybe time for a modern conversion. A useful point though. Thanks.
    May 2014
    81
    Many thanks. Looks good. I'll get in touch. Did you have them fitted by a garage or did you do it yourself?
    May 2014
    81
    Quote Originally Posted by laurie_lewis View Post
    C5 | Towbars Australia
    I should have included this quote. Sorry. They look good. How did you have them fitted?
    Armidale, NSW
    234
    Allen I was lazy and got a garage to fit it for me.
