Xantia HDI speed sensor-can I drive without one?
    Jun 2016
    Auckland, New Zealand
    7
    Icon4 Xantia HDI speed sensor-can I drive without one?
    Hi there-
    I've been having intermittent issues with my speedo, and it finally stopped today. I've looked around a bit, and am pretty sure it's the speed sensor. I'll hopefully get the part within a few days, but I was wondering of it's ok to drive the car short term until I get it fitted?? It's a manual, so I'm pretty sure transmission will be fine, I just don't know if the speed sensor controls any other engine functions (apart from ABS possibly?) Any thoughts and wisdom would be much appreciated- as I don't want to damage anything.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    624
    will be fine, speed sensor is only used for speedo,
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    10,783
    There are posts here on Xantia speedos. They can fail, sometimes after going intermittently, because of four soldered joints on a circuit board - easy fix once the speedo is out (!). Others (not I) have done this and posted on the subject. It is the four larger ones that form a square/diamond in the inner part of the board - I presume it is repeated expansion/contraction normal to the plane of the circuit board, the joint cracks and it goes intermittent before failing completely.
    I pulled one apart once, and the cracking where the wire came through the solder was quite visible.
    Attached Thumbnails Attached Thumbnails Xantia HDI speed sensor-can I drive without one?-xantia-speedo-circuit-board.jpg
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Jun 2016
    7
    Great, thanks heaps for the replies. If the new sensor doesn't work, the picture will definitely come in handy.
