CX Mirrors
Results 1 to 3 of 3
Thread: CX Mirrors
    Fellow Frogger! laurie_lewis's Avatar
    Armidale, NSW
    234
    Default CX Mirrors
    Does anyone have any advice on how to take these mirrors apart. I think the electric movement has become detached from the back of the mirror.
    Laurie
    Sent from my iPhone using aussiefrogs mobile app
    16,426
    Heat the glass with a hair drier, there should be double sided tape behind them that lets go when hot... There is a grub screw under the plastic cap on the door if you wish to unscrew them (from memory).
    Shane l.
    9,777
    This is what you would find inside the earlier rectangular items (taken a few years ago) ....
    They may or may not be the same inside your mirror housing. Sometimes, you will find the mirror glass is glued to a plastic back that is retained by a lock ring of sorts that can be locked or released by rotating it with a thin rod inserted through a hole in the bottom of the housing. See if you can determine how it;s retained and maybe look for pictures of the mirror in bits. Perhaps, the front cover comes off to reveal the mechanism as it does on later models?
