CX 2 Misc Questions
Results 1 to 11 of 11
Like Tree3Likes
  • 2 Post By David S
  • 1 Post By leregulage
Thread: CX 2 Misc Questions
    Fellow Frogger! leregulage's Avatar
    The hills of Virginia
    136
    Default CX 2 Misc Questions
    Hi everyone in Citroen land!
    Its been a while since seeking the the help of Le Frog community. Now I have found my way to Citroens.
    Today a 88 CXA 25 2.5 injected Prestige arrived today in Virginia. Since I've never touched one, until 4 hours ago. I must ask a few things.
    Does anyone have a owners manual for the car?
    I have a Haynes book on the way. Already printed the factory one.
    She has a few LHM leaks, cracked brake hoses-I can go on. It does raise and lower just fine though. When in the high up selection. The stop lights come on. Pass front ram thingy leaks a lot....
    Of course the big one. Where do you guys get your parts from? I know of western hemispheres in the USA.
    I tried the search feature, with no luck. Might have been the way I did it. So if all this is already covered somewhere-
    "Me so sorry"!
    Adam.CX 2 Misc Questions-21121.jpgCX 2 Misc Questions-21122.jpgCX 2 Misc Questions-21123.jpg
    10,797
    That looks nice.
    Try googling "CX Basis" - good parts supplier in Germany with a good on line catalogue. Don't buy except in batches as postage is a minimum 40 Euro, or was last time I needed them.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    16,421
    small LHM leaks will just be the return lines. It will probably need new "octopuses". There is two branches of return lines that can split as they age ( 30+ years). You can repair them, but as the lines are old and deteriated the repair never lasts. It's not a big job to fit new return lines and fix the issue into the distant future though.
    Flashing light on high just means the reseviour needs to be topped up. USE ONLY LHM NEVER EVER BRAKE FLUID !!!
    136
    Very good then. When it dries out, I'll report back with my findings.
    Fellow Frogger! CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    986
    Nice looking car Adam.
    As Shane says, put the suspension on high with the engine running and check the LHM level. Sounds like it will need a top up. Make sure you only use genuine LHM. Penrite make a good LHM, now called LHM Plus, which you should be able to get hold of over there. Top it up until the float is between the guide lines on the glass bubble at the reservoir when the car is on "high".
    Enjoy.!
    Cheers, Peter J
    Current - 1974 D Special
    : 1976 16TS
    Previous - 1984 CX 25 IE : 1976 16TS : 1979 12 Virage
    Jun 2015
    Narrabri, NSW
    986
    Here is the CX Basis shop page Adam. CX-BASIS :: eShop
    Cheers, Peter J
    : 1976 16TS
    9,774
    Make sure you read and understand this thread re the risk of being crushed under the vehicles. Don't take chances!
    Hydraulic Citroen Safety - also applies in part to other cars
    You can find more manuals and information via:
    https://sites.google.com/site/citroenpublicationslist/
    You may find a handbook there, but USA would presumably be a different print to other markets. You have very little chance of finding one from this end of the world though. eBay or even Abebooks?
    Jaguar and RR and Maserati used the mineral oil systems in some of their products, so those are other options for LHM if you get stuck. Total is not the only supplier of the stuff and it's sold via Bendix, Ferodo, Penrite, Castrol and so on.
    CXVingtCinq and UFO like this.
    136
    Will read up on now. Don't wanna get squished like a bug!
    UFO likes this.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    You have found yourself one of the best cars ever built. Fix the LHM leaks, I would suggest buying new hoses from CX basis for all the return lines. Not that many on a CX and not that hard to fit. While you are at it buy a new tank to pump suction line and that will replace all the rubber lines. As part of your order, get a pair of flywheel sensors, one thing to always have as a spare in the boot.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    16,421
    Quote Originally Posted by Greg C View Post
    Did you notice his car is a Prestige He should only need 1 flywheel sensor being an '88 model
    Oct 2003
    1,304
    Didn't know they changed it. Still one is always a good spare.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
