Cit C4 hatch will not open.
Results 1 to 7 of 7
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,046
    Default Cit C4 hatch will not open.
    Any ideas on how to open the hatch of my C4.
    All other doors unlock but the hatch will not.
    Is there a mechanism linked to a solenoid that may be loose?
    DS 21
    C4 HDI
    Piaggio Fly 125
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Cast a wide net using google. Try the english french car forum or the C4 owners website for clues.
    You are probably lucky it is a hatch. Put the back seats down and get in close to the boot lock area with a torch. See if you can take some trim bits out and you may be able to access the bolts that hold the hook piece on. The at least you can raise the hatch to get into that and find out what is going on the with the lock.
    Maybe you can take the inside panel off the hatch from the inside and get to the lock that way.
    The Haynes Series 1 C4 Manual may have some helpful pictures in it.
    Cheers, Ken
    8,774
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    492
    I think you will find that it is only slightly catching. Try pressing down on the lid and then quickly lifting. If this works, then adjust the positioning of the U (upside down view) static catch with a 13 mm (from memory) socket.
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    1,046
    Thank you, I think the page from seasink will do the trick.
    DS 21
    C4 HDI
    Piaggio Fly 125
    1,046
    The car is at the repairers, it is their problem.
    All doors unlock but not the hatch.
    It was working but then stopped.
    I just want my car back.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Sep 2005
    187
    It is fairly easy to open the lock from inside as described in the manual.
    I think you will find the wiring loom ( top left hand side - with in a rubber concertina cover has a broken wire. Usually this location is where the wires all flex repeatedly as you open and close it. Hawk
