C5 (X7) brake rotors
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Ken W
  • 1 Post By AllenM
Thread: C5 (X7) brake rotors
    Jul 2015
    Ipswich
    45
    Default C5 (X7) brake rotors
    Hey again....just tapping into the communal knowledge out there ...I shortly will need to replace the rear rotors on my car. No probs I thought, I'll just call my usual supplier (Brake Parts Australia) as they import components for a lot of cars....but no compatible reference??
    Any ideas? This isn't a dealer only item is it? Maybe a Peugeot 508 part is the same?
    Cheers again!
    Tony
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Try Caravelle or EAI in Melbourne or for local call John Walton at DS Motors and see what he can get you. Have your VIN ready when you call.
    Otherwise, create yourself a independent mechanic account on service.citroen.com, plug in your VIN, get the part numbers and google or ebay search the part number.
    Cheers, Ken
    antonio likes this.
    Jul 2015
    Ipswich
    45
    Thanks Ken, should have thought of that myself!
    North Brisbane
    1,925
    Here is a previous thread on the topic of actually doing the job.
    C5 X7 - replace rear discs and pads - easy or hard?
    Cheers, Ken
    8,755
    Quinton Hazell are the easiest to find here, and EAI in Sydney 02 9481 8400, or Melbourne, mentioned above, can supply them and put them on a courier - EAI: Quinton Hazell. They have the pads also.
    The rear calipers are fixed, German Teves, not the common floating, but the job is simple. Two things I have found - be creative or persevere if a ridge on the outer disc stops the pads sliding out easily, and have a piston tool ready to wind in the handbrake adjustment on the piston. It isn't essential but it is difficult without it. There are a few brands, like this:
    Most important of all - disable the automatic parking brake! Totally! If it operates with the brakes dismantled, you will roger the whole expensive thing.
    Brisbane Australia
    162
    If you haven’t made a move already perhaps these addresses will help. I have used bhss and found them very good. Without the piston rewind tool you will really struggle. I have used 100mm grinder to remove enough of the lip to get the rotor out of the caliper.
    BHSS Automotive Engineering - Home
    Giantz Universal Disc Brake Caliper Piston Rewind Tool KIT SET Auto Windback CAR | eBay
    addo likes this.
    Don't remind me!
    16,609
    Second link is good, that's what I was referring Stuey to yesterday but your price is better by 2/3.
    Jul 2015
    Ipswich
    45
    Guys thanks for the feedback. If anyone is interested here is what I have been quoted:
    BPA - Brake Parts Aust - nothing compatible
    EAI - $265
    Imparts - $251
    BHSS - $240
    These quotes are for rear rotors and pads; both EAI and Imparts checked against VIN to make sure of accuracy, BHSS would need me to measure the rotors first to be sure. All three have the parts in stock although EAI have to freight from Melbourne (included in quote) whereas Imparts are at Eagle Farm.
    Cheers!
    8,755
    Thanks for that. I didn't know that Imparts could help with Citroen. Which brand are the pads and discs?
    Jul 2015
    Ipswich
    45
    ..update...Future Automotive can do parts for $245 and labour $140...they are welcome to the mess and hassle; I have Uni assignments to get done!
