Xantia regulator Question!
Results 1 to 3 of 3
    Ici.
    2,560
    Default Xantia regulator Question!
    ok weeping regulator on xantia, I see it coming from pressure release valve, am I hallucinating?
    Want to change the seal on valve but do it at the seal shop in the parking area!
    ie drop the suspension, remove valve bolt and prise out o ring take it into the shop and say I want one this size, go back out and put it in and drive off.
    Having never messed with a regulator I suspect the ball might want to pop out so keeping an eye out for that.
    Am I going to start a torrent of LHM?
    Does this sound like a bad idea? !
    Brains trust advice required.
    Steven
    9,770
    It will leak, so get the seal first and change it later. A weep is better than a torrent. Also, you risk losing the ball in the carpark, which then means a tow. The size is common to other applications, but should be:
    4026 82 HYDRAULIC OIL O-RING SEAL DIAM 6 x T1.9, which I think I noted from the BX listing.
    It will have different numbers, but is the same part for earlier models.
    I don't think it's broken down further than the regulator unit for Xantia and XM.
    Also, the o-ring is on the screw/bolt, not inside the hole.
    Ici.
    2,560
    Thankyou David all understood and appreciated.
