SM Muffler Mtg
Thread: SM Muffler Mtg
    Kapunda
    456
    Default SM Muffler Mtg
    While replacing the starter motor I noticed that one of the Muffler mounting brackets has broken.It is attached to a large rubber block in the subframe.It is not obvious how any of these is removed, advise required please.
    Woody
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Are you referring to the big rubber bump stop that goes on one side of the front transverse muffler?
    Check in the relevant exploded diagram in the parts pdf to see how it comes apart.
    Cheers, Ken
    Apr 2014
    Phoenix, Arizona USA
    674
    The main muffler is held on both sides by a molded rubber wedge-shaped thing (about 4 x 4 x 4 inches) that has the steel mounting flange cast in. You have to remove the muffler then pry/pull the rubber wedge out of the socket in the frame.
    John T.
    Kapunda
    456
    Thanks John,I,ll give it a go tomorrow.
    Woody
