Berlingo 1.6 Diesel fuel pump - expensive death
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By badabec
  • 1 Post By furneauxfrogger
Thread: Berlingo 1.6 Diesel fuel pump - expensive death
    Member Mitchell's Avatar
    Perth
    97
    Default Berlingo 1.6 Diesel fuel pump - expensive death
    Howdy all,
    One of our 1.6 diesel Berlingos (2011) has died. Turns out it is the high pressure fuel pump.
    It would seem that the dealer wants $4000 for a replacement.
    Has anyone else found a more economical solution to this repair?
    Thanks & regards,
    Rhys
    Don't remind me!
    16,609
    Really? Sure it's not the lift pump? Has the drive sheared internally or the pump started to digest itself with evidential metal particles?
    I'd be messaging "207CC" or whatever his name is who posts in the Pug forum, see if you can get a referral to his UK contact with lengthy tentacles.
    Perth
    97
    Addo,
    The van was taken directly to the dealer - so the diagnosis is theirs. I haven't seen the aftermath of the fault so can't provide any clues to a sensible diagnosis.
    Rhys
    Don't remind me!
    16,609
    Dean and Dean Jr have one, assuming it's a 1920HT:
    PEUGEOT DV4VTED DV6VTED NEW Bosch Diesel Fuel Pump 0445010102 9656300380 1920HT | eBay
    Call them, they can knock off the VAT for exports.
    I'm suspecting they are getting a low pressure reading at the pressure sensor, but that it's not getting enough fuel supplied to build up the correct head of pressure.
    I was contemplating these ones (and some other models) the other day, thinking it would be useful to have a test unit that used its own mini tank and lift pump to feed into the existing filter.
    tweed heads
    1,489
    If its on a return basis from the uk check out the cost to return post, on the old one ,in my case it was as much as the deposit .after all the hassle it was the lift pump anyway .miss diagnosed ,low rail pressure .this was on a 2000 peugeot 306 ,it all started when my son fitted one of those electronic boxes [that tells lies to the computer ,seems the ecu believed it and shut the motor down due to low rail pressure ,,get a second opinion ,pugs ps as the fuel lubricates the moving parts in the high pressure pump the ecu shuts it down before it seizes up
    Perth
    97
    Thanks for the advice addo & pugwash.
    As luck would have it - one of our other Berlingo's was involved in an accident the following day. An insurance right-off looks likely, which will enable us to retain the wreck and utilise the parts.
    Rhys
    Feb 2012
    Ongar / England
    832
    Did it crash into the Berlingo with the dodgy pump?
    jaahn likes this.
    Jun 2011
    Flinders Island Tasmania
    96
    Quote Originally Posted by badabec View Post
    classic.... LOL
    Jun 2011
    96
    Quote Originally Posted by Mitchell View Post
    Rhys
    Not often you here the words "as luck would have it........... an insurance right off looks likely"......... lol
    jaahn likes this.
