CX 25GTI Auto wont start
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By Balki
  • 1 Post By gerrypro
  • 1 Post By DoubleChevron
Thread: CX 25GTI Auto wont start
    Mar 2015
    United Kingdom
    13
    Default CX 25GTI Auto wont start
    Hello.
    Anyone got a pointer towards what is wrong please.
    Three weeks ago I went a really good brisk run with the CX. No problems and very enjoyable. Came to start it yesterday first time since that run. Engine spins over fine, all I am getting is popping and banging in the exhaust. Nearly fires into life but will not quite make it.
    Any suggestions please.
    JohnT
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    625
    fuel preassure
    johnmowcop likes this.
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Mar 2015
    United Kingdom
    13
    Thanks Balki.
    Been having a sniff around other forums. Seems likely one of the following:
    Something called a "big Blue" fuel relay.
    Connection in right and side front footwell.
    Connection at pump or pump itself.
    Do you have any thoughts on these please.
    JohnT
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    As Far As I Know, Shane carries a spare timing sensor around with him just for cases like this. It seems that they fail without warning!
    Cheers Gerry
    16,421
    What year is the CX
    Have a look at see if the intake hose is off. Does the fuel pump cycle on/off when you turn the key. Can you hear the fuel pump buzzing when you crank the engine Do you have power to the coils, power to the injectors .... flywheels sensors usually go heat sensitive, so work when the engine is cold.
    CitroŽn Tragic UFO's Avatar
    9,721
    Quote Originally Posted by johnmowcop View Post
    Thanks Balki.
    JohnT
    "Big Blue" is usually near the battery and is quite a large relay, remarkably, coloured blue. A gentle tap may wake it up enough to work for a while - or not. Some will tell you that it is no longer available, but there IS a Bosch equivalent; Have a read of THIS THREAD from years ago for the part number and more info.
    9,721
    BTW - the Bosch relay is black.
    16,421
    The relays and computers move around dependent on year or model. I've found the tachometric relay doesn't so much die, as the wiring plug onto it becomes intermittent The tachometric relay is under the front right headlight in mine. I think some have it inside the cabin!
