SM Starter Motor removal
Results 1 to 2 of 2
    Kapunda
    456
    Default SM Starter Motor removal
    Advise please.My guess is that it is below the RHS cylinder head.Do I tackle this job from above or below?
    Woody
    Apr 2014
    Phoenix, Arizona USA
    674
    Work from below.
    Remove the cable and the switch wire.
    If you have an early 2.7 with the socket head bolts, you can get both with socket and a long extension after you remove the heat shield
    If you have a later car with the studs and 17mm hex you can get the upper one with a socket. The lower one goes one flat at a time since it is right above the crossmember.
    John T.
