I'll have what Harry's having. . .
Results 1 to 25 of 25
Like Tree15Likes
  • 2 Post By GreenBlood
  • 2 Post By wilrex
  • 2 Post By harrisson_citroen
  • 2 Post By UFO
  • 4 Post By dsvitesse1
  • 1 Post By dsvitesse1
Thread: I'll have what Harry's having. . .
    8,184
    Icon6 I'll have what Harry's having. . .
    Forget Sally, I''l have what Harry's having. . .
    DS 23IE 5 speed BVH with a few mods - hydraulic handbrake on rear wheels - a little engine management tweaking, oh and Diravi steering. . .
    CXVingtCinq and ds21bvh like this.
    08 C5 X7 HDi very Noir
    Apr 2014
    Phoenix, Arizona USA
    674
    Delta Mic wheels, too.
    John T.
    16,415
    So that is what Harry looks like ... That's a really nicely made video. I'm glad they subtitled it!
    PS: So how did he get the hydraulic handbrake working
    Ici.
    2,560
    Awesome. Great to see someone chucking one around too.
    8,184
    Icon3
    It would be good to hear from Harry (he occasionally looks in)
    My guess would be that he uses an isolator incorporated into the lever beside the driver which when activated closes off pressure to the front circuit and applies pressure only to the rear, the lever perhaps giving some feel as to what extent
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,024
    Makes my efforts in Moby Dick look a bit tame!
    I notice he says they installed "Hydraulic Breaks" so maybe the braking system has been completely converted to a separate system in which case running the rear circuit through a master cylinder (like is done on "normal" rally cars here) and attaching the 'turning lever' to it would achieve the result.
    Personally I like the feeling of having 2500psi of braking power available at the twitch of a toe.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's)
    1974 D Special Manual Sedan ("Moby Dick")
    2006 C5 HDI Wagon Auto ("Mephistopheles")
    1982 2CV6 ("Gaston") Seasoned traveller
    1975 GS Pallas ("GiSelle") Next project
    Dec 2005
    Crows Nest, Queensland
    165
    I'd love to know more about the modern engine management system and where to buy wheels like that. Cheers. Robin
    16,415
    I rekocn you could grab high pressure into a doseur valve. Using only the front output ... "T" it into the rear brake circuit. You could have the lever pushing against the doseur. The only issue I could see if if you applied the main brakes at the same time, the pressure would back feed through to the rear suspension and raise the rear of the car.
    edit: no the DS has a trolley valve on the main brakes, not a doseur, I'm not sure what higher pressure back feeding the trolley valve would do
    seeya
    shane L.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Take another feed from the rear suspension circuit, feed through a doseur valve pinched from a CX and feed into the rear brake circuit. The doseur valve is just a pressure transformer so I don't see how it can feed pressure back into the suspension circuit or the other brake circuit. He probable has another brake pedal to operate it. The new way to left foot brake.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    16,415
    Quote Originally Posted by Greg C View Post
    It has to be from high pressure. You will not get enough pressure to lock the wheels from the rear suspension circuit
    Member wilrex's Avatar
    Oct 2014
    Buninyong
    79
    Would make a good entry for the Netherlander Hill Climb Championships. (speed bumps)
    STALLED and Demannu like this.
    2CV6 Special Green, Riley RMB, RX7 Rotary, Jensen Healey, 1896 Ford A replica, and last but not least 1961 Citroen ID19-P... Previous include, 27 Chev Truck, 24 Bean Truck, 27 Chev Capitol, Rover S105, Humber Hawk x 2, MGB, Ford AA Truck, Ford A, elderly motorbikes x6, and more...
    8,184
    Icon3
    This looks like a lever to control the rear brakes, so no additional pedals?
    Attached Thumbnails Attached Thumbnails I'll  have what Harry's having. . .-harry-rear-brakes.jpg
    Citroën Tragic UFO's Avatar
    9,719
    With Harry's engineering skills and knowledge of Citroen systems it appears there is little he cannot achieve. He's a lovely bloke too - always good for a chat and a laugh at ICCCR.
    9,719
    I'll copy the link for this thread and share it to him on FB.
    Feb 2002
    Coolum Beach
    1,914
    HARRY MARTENS......
    plus he works on Borg Warners
    addo and UFO like this.
    DS Un jour, DS toujours !
    DS23 IE Pallas Automatique
    C5 X7 163 Exclusive
    C3 II 2010
    Apr 2014
    674
    Quote Originally Posted by Robin Hoffmann View Post
    Those are period aftermarket Delta Mic wheels. They are almost as hard to find as original Rous Resine wheels. For what it's worth though, you can fit of all things, the wheels from a Ford Transit Van. There are some fairly attractive aftermarket wheels for the Transit IMHO. As far as I know the Transit is the only other vehicle on the planet with a 5 x 160mm bolt pattern. The ET is a bit more so you may have to fit a spacer.
    John T.
    9,719
    i have some fresh pics from Harry just received via Facebook. He's onsite ready for the day to kick off in about 90 minutes.
    Now if I could just get AF to upload the pics...
    Dec 2005
    165
    For Harry, I'd love to know more about the modern engine management system. Have you ever thought about putting together a kit so that 21 IE and 23 IE owners like me could upgrade to a more modern system if they wanted to. The D-Jetronic ECUs are starting to show their age with dry joints, failed components etc. I had mine overhauled/resoldered and I have a spare 23 IE ECU (complete, but very rusty 5 speed car actually), but that option isn't always going to be around. Cheers, Robin
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Me too. I'm wondering if maybe it uses a Lumenition eye to drive a Megasquirt?
    Also wondering whether it's on standard spheres or has got XM firmness regulators fitted. I did that to the front of my D to great effect.
    Like the car Harry
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    9,719
    Pics from HarryI'll  have what Harry's having. . .-harry-1.jpgI'll  have what Harry's having. . .-harry2.jpgI'll  have what Harry's having. . .-harry3.jpgI'll  have what Harry's having. . .-harry4.jpgI'll  have what Harry's having. . .-harry5.jpg
    Don't remind me!
    16,609
    Maybe it's a bridge not joined here but on Crackbook; I can't find out what event the display is at.
    8,184
    Best guess Citromobile Amsterdam - Huge event!!
    CitroMobile Startpagina english
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    W
    Pics from HarryClick image for larger version.
ID:	84040Click image for larger version.
ID:	84041Click image for larger version.
ID:	84042Click image for larger version.
ID:	84043Click image for larger version.
    How do we get those rotors in the 2nd last pic!!!?
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Jan 2011
    netherlands
    45
    Hi, this is how I installed the hydraulic handbrake.I'll  have what Harry's having. . .-img_2463.jpg
    addo, GreenBlood, Fingers and 1 others like this.
    Jan 2011
    netherlands
    45
    Special rotors will be installed in my car in the coming few weeks. Will keep you updated how all is working and if I will make kit.
    cheers,
    Harry,
    Thanks guys.
    UFO likes this.
