DS 23 IE Throttle Cable Replacement
Results 1 to 8 of 8
    Apr 2013
    Essendon
    660
    Default DS 23 IE Throttle Cable Replacement
    Any advice as to how to go about an insitu replacement of a throttle cable would be appreciated
    Looking at it today, it appears that it would be nice for the motor to come out!
    John
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    The cable at its lower end has like a big ring connector on it. That slips over a bush on the passenger side of the big throttle lever that goes under the sump on a RHD car. I forget how it is held on, a small wire clip or similar, but it can be seen from underneath - space is very narrow but the cable end can be taken off the throttle lever. The cable then passes up to the passenger side engine mount bracket and over a little wheel there and then up towards the inlet manifold.
    Unless the old cable is broken, I'd be tempted to check the cable end is free to rotate on the bush from beneath the car; and then that the cable passes over the little wheel ok (for which I suspect access is diabolical). The little wheel is held on with a shaft and it may have seized up or the cable dropped off it.
    It'd definitely be easier to replace with the engine out (!). I remember being told years ago to be sure the passenger side engine mount bracket and cable is in place on an EFI car before putting the engine back in, because it can't be fitted afterwards.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Kapunda
    457
    Also make sure that the plastic pulley is still intact ,they
    have a flimsy outer section which usually disintegrates,I,ve replaced mine with a Brass one!
    Woody
    Apr 2013
    Essendon
    660
    Thanks Marc and Woody,
    Access is certainly diabolical under there and great advice to any IE (RHD) owner to check that throttle cable before motor goes back in. I discovered that mine was badly frayed at the IE throttle housing and it would have been a matter of time that it would have failed - a new one needs to be installed.
    I'll have a closer look as to how the cable ring end is secured to the linkage lever that goes around the sump.
    John
    Quote Originally Posted by marc61 View Post
    Marc
    Apr 2013
    Essendon
    660
    All is as described by Marc and Woody. This has got to be the most difficult assignment in my 50+ years of working on motor vehicles.
    Closer look revealed that the cable ring end is retained by what appeared to be a wire retaining clip that I was not prepared to attempt to remove as there is no way of getting back on. ("I say appeared" as it was very dirty and eyesight is not as good as it was).
    Nevertheless, every thing worked OK - nothing ceased.
    Very keen to find out if anybody has done it before, that is that it can be done or has been done before I attempt it.
    In the interim, I'll leave it as is and work on the frayed end and leave the new cable until the motor comes out.
    Once again, I'd like confirmation that the IE throttle cable can be replaced insitu, that is with the motor in place.
    John
    Quote Originally Posted by JAJEA View Post
    John
    Apr 2013
    Essendon
    660
    HAS anybody replaced the accelerator cable on a road going DS 23 IE ?
    John
    Apr 2013
    Essendon
    660
    With the help of UK Aussie frogs the cable is out without removal of motor! (This to a 23 IE with the automatic gearbox!)
    Relatively straight forward albeit a bit tight between motor and body. (This is post removal of cable from IE manifold.)
    1. From the top LHS of motor follow cable down and remove clip holding/securing end of cable. Relatively long screw driver required.)
    2. From underneath the D remove the spring clip (long nose pliers) and pull out spindle to remove the spring loaded mechanism that I believe is unique to the automatic D.
    DS 23 IE Throttle Cable Replacement-img_4613-2-.jpgDS 23 IE Throttle Cable Replacement-img_4614-2-.jpg
    3. With the cable free from the throttle mechanism within the body, from the top, reach down and "weave the cable" out of the roller aligning mechanism. Photo of complete cable removed from D with end fixing separated (there is a split pin holding cable end within compression retaining enclosure not included.
    $. Cable taken to Flexdrives (Stubbs Street Kensington Victoria) to be refurbished with new stainless steel cable and end fittings to be picked up next week - cost estimated to be AU$30 - 40; I did not worry about a firm price considering that if the ordered cable had arrived it would have been of little use to me.
    The throttle cable for an automatic D needs the manifold fixing mechanism to be part of the "new", the ball end fixing to the throttle butterfly does not fit! It has to be made up as a unit! You can see why I had elected to replace - not sure how many strands were holding but it was just a matter of time before they all gave way.
    Rally prepared is the way to go!
    Wish me luck for next week in the reassembly process.
    John
    John
    Apr 2013
    Essendon
    660
    Cable picked up from Flexdrive - final cost $49.36 based on actual time and materials (no position to argue on the estimate quote as it was an estimate); nevertheless cable is as per IMG 4611 (4th photo above). Ideally suited.
    Installation has been achieved being the reversal of the previous removal update; not too difficult, it would have been much easier if eyesight was better - multi focal lens make things difficult in their own right!
    John
ID:	84324Click image for larger version.
    John
