DS Air filter
Thread: DS Air filter
    Mar 2011
    Ireland
    144
    Default DS Air filter
    Hi All,
    The end of my air filter(cream one) is hitting against the top radiator hose(23 manual carb). Am I missing some spacers or should I have the black filter, is it shorter?
    Ed
    Mar 2011
    Ireland
    144
    Mar 2011
    Broom
    816
    I seem to recall adding spacers/washers to both studs under the bracket in an attempt to gain more clearance from the top hose. Wasn't that successful, then I realised raising the forward mount above the rear mount will amplify the result.
    Mar 2011
    Ireland
    144
    Hi,
    Yes a thick washer under the front mount solved the problem. I feel a little stupid that it was so easy to solve. I was envisaging collapsed engine mounts or similar!!
    Ed
