Xsara 1.6, noisy timing belt?
    Jerangle
    784
    Default Xsara 1.6, noisy timing belt?
    Just fitted a new Gates belt to our Xsara and it's noisy ?
    The Gates belts are very stiff.
    Does the noise go away with use and this normal.?
    I re-did it and replaced the tensioner , adjusted the tensioner so the pointer was below the head joint.
    Tension was right but there was still a little noise.
    *In the manual it shows a different tensioner which is loaded the other way, arrow is to the right, where-as this one is to the left.
    Anyone got the setting diagram for the other type , also used on P206?
    Newcastle
    2,624
    Hi
    I am not familiar with this particular engine so take this comment generally !
    The only time I had a problem with a noisy new timing belt it turned out the tooth form was incorrect. Solved by having the correct belt put on. The Ford dealer had fitted it by the way, on a Ford work ute.
    Jaahn
    Jerangle
    784
    Tooth profile is correct.
    The Gates belt is a very strong belt and i am wondering if they bed in with use and begin to flex a little.
    Apr 2017
    Forest Side/Curepipe/Mauritius
    8
    Hi, can you please send a snap shot of how it is installed in the manual? I have a Xsara 1.4 and I'm having the same issue.
