Ds23 sticking accelerator
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By GreenBlood
Thread: Ds23 sticking accelerator
    Jun 2015
    Ashburton
    198
    Default Ds23 sticking accelerator
    Accelerator catches at top of throw making ride uncomfortable. Have lubed all the likely suspects. Any ideas before I pull it apart ?
    Jun 2015
    Ashburton
    198
    Quote Originally Posted by PeterMol View Post
    Illogical as it sounds it only seems to happen when engine is warm
    San Diego, California, USA
    3,533
    I forget Peter, are you carb or injection? It sounds very much like something is maladjusted. Unlikely, but it could also be something is bent. You don't have to strip it all apart, just check and make sure it's properly assembled and adjusted. Also, make sure you don't have anything interfering with the pedal itself. A piece of carpet askew can create your headache.
    Aug 2011
    407
    Peter, I had that a while back. I fiddled around adjusting the mechanism through trial and error. Didn't actually disassemble anything. I assume you have the repair manuals?
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,344
    If it is associated with heat then think about what things in the linkage are affected by heat. I would suggest the carby (assuming it's a carby model, or the butterfly linkage if EFI).
    Roger
    8,184
    Icon3
    Have a look at the condition of the bearing mount on the firewall behind the carb - this was mine before replacing, the bronze bush is well worn and the rubber cracked and crazed.
    You can buy replacements but I found a kit available on ebay in the USA using a nylon bush for only a few dollars.
    The difference after replacing is staggering, smooth pedal travel through the range.
    Certainly worth a look
    Hotrodelectric and UFO like this.
    08 C5 X7 HDi very Noir
    Citroën Tragic UFO's Avatar
    9,719
    ^^^ wot he said ^^^^
    Jun 2015
    Ashburton
    198
    Thanks all. Weekend got away from me so it will need to wait a few days. Is there a linkage behind the plastic or cardboard cover under the brake. The pedal link age seem to go in there and if I am not mistaken I can hear something click when it gets stuck. Car is a 23 Carby. Anyway you have all given me great food for thought
    9,769
    Yes, the pedal moves a rod inside a pressed steel assembly that is hidden under the carpet and rubber brake pedal surround. The rod then passes through the side of the footwell into the engine bay. The rod could become sticky if it need lubrication. Maybe, unhook the carby and see if it is the carby or the linkage sticking.
    It will be a Weber on a 23 and there is a procedure to set up the linkage between the two barrels. You want to make sure it is correct or the carby will never work correctly. I remember playing with one on a Special that was gutless and it turned out the linkage was wrongly set up and it jammed before opening the second barrel. I'm not sure if it could make the throttle jam, but it may be worth removing it and following the manual set up if there is any doubt about how it has been adjusted.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    It's worth checking underneath the car that the big u-shaped bracket (that transfers movement from the RHD throttle pedal rod to the threaded rod in the vicinity of the carb) is moving freely/correctly. There's an M7 clamp bolt from memory on one end of it that can eventually work loose and the other end has a nipple that sits in a bearing of sorts, which can jump out.
    Then it's worth checking from underneath that the threaded rod on the carb side of the engine is free to move up and down, and the springs likewise. Space is very tight down there, so the rod can easily rub against something.
    Its a 1950s mechanical arrangement - over the years I've had the bolt not clamp properly, the bolt work loose, the nipple jump out, the rod rub against something and it always manifested as a sticky or jumpy throttle. I finally solved all of that by deleting the threaded rod and fitting a throttle cable, which was a truly momentous improvement, but that's another story.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
