Is there a thread on, or includes within it something on rotors for d's?
Results 1 to 18 of 18
Like Tree5Likes
  • 1 Post By addo
  • 2 Post By daffyduck
  • 1 Post By GreenBlood
  • 1 Post By forumnoreason
Thread: Is there a thread on, or includes within it something on rotors for d's?
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    Default Is there a thread on, or includes within it something on rotors for d's?
    Want better quality material than the ones on it at the moment.
    Cheers.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Mar 2011
    Broom
    816
    If by 'better material' you mean steel hardness, I believe the steel was softer on lift up door handle cars.
    What's wrong with the discs you currently have on the car?
    Perhaps they're non genuine or perhaps when they were fitted, the runout wasn't checked properly?
    Faulconbridge
    2,479
    The quality went south after the 69 model;years ago I sourced a 69set for the 21,all good.
    Jan 2015
    A comfy place.
    319
    Looking at them and comparing them to the km the car has traveled they must have been replaced not too long (km wise) before we purchased it as there is no wear lip what-so-ever, and they are very thick indicating no machining. They were fine until July last year when we came back down from the Lakes in Tassie down the looong hill. They started to vibrate/pulse indicating that cementite reaction that occurs on cheaper rotors. Ever since it's just getting worse and worse. I'd say they are non genuine, maybe a cheap knock off. I'm hoping there are rotors made of better quality steel being made. (Carbon ceramics maybe I hope so I can do stops from 300km/h)
    Gillian and Chris
    Oh, and a Holden.
    Feb 2005
    rosevale/tasmania
    2,754
    Chris, I gather that that issue responds to machining (until the next time its induced anyway).
    cheers! Peter
    Jan 2015
    A comfy place.
    319
    cheers! Peter
    Shouldn't have to Pete, they shouldn't get that build up, and especially from only moderate braking. It first began that day last year up the lakes. I was hoping rotors may have been investigated by others already. Lance Collins states it is a problem I was hoping there was more than one manufacturer.
    Gillian and Chris
    Oh, and a Holden.
    9,769
    Have you done any checks on the runout with a dial gauge or pointer to confirm distortion? Mounts OK and the caliper bolts tight? The bolts have a torque, but 'FT', done with the brakes applied hard to centre everything has been suggested as on recipe for setting up. With so many cars built, there would have to be a selection of suppliers if you go digging.
    Jan 2015
    A comfy place.
    319
    It was fine for 6 months or more until we came down the big hill, plus I've drven many cars with cheap rotors that did it from hard braking.
    Gillian and Chris
    Oh, and a Holden.
    Don't remind me!
    16,609
    I have noticed Tar-Ox reckon they do a range of "to spec" rotors for odd cars; the English website is a bit clunky in places - maybe email them or call?
    Lasya likes this.
    Los Angeles, CA USA
    1,955
    Brake judder can be caused by contaminated brake pads. Is the radiator drain hose present so that coolant overboard doesn't dribble on the pads?
    D rotors are horrifically difficult to get true using a standard automotive brake lathe. A larger lathe for trucks and bus drums and discs is the ticket to getting them true.
    If the park brake pads are set too tight, you can cook a rotor: cooked rotors a rare in a 5 main DS for the most part.
    Don't remind me!
    16,609
    I honestly thought it was the rotors' metallurgy which was deficient in repop items, was sure one of the perfectionists had tales of them refusing to stay true even after Blanchard grinding.
    8,184
    Icon12
    Quote Originally Posted by daffyduck View Post
    Good points, Chris, also check you don't have LHM leaking past the piston seals onto the pads.
    With the banning of asbestos in the manufacture of brake pads, sourcing a reliable supplier for replacements is as important as for discs.
    Maybe you need this factory tool. . .
    Attached Thumbnails Attached Thumbnails Is there a thread on, or includes within it something on rotors for d's?-brake-grinding.jpg
    08 C5 X7 HDi very Noir
    Mar 2011
    somerset
    35
    Since the banning of asbestos it seems that rotors in all makes of cars appear to wear out at about 100K or less in some. Guess that asbestos is soft and current pads are harder than they used to be which would explain it. Discs also get hotter now than they used to do. Now you seem to have pay for replacement rotors or disc pads much earlier than we are used to. Manufacturers also appear to allow for less wear on the rotors before they demand replacement. Join the club Chris !
    Jan 2015
    A comfy place.
    319
    First thing I did when I bought it was add extra an extra length to run it behind the rotor. Doesn't appear to be any LHM leaking onto them either. I don't care about wear, just the severe juddering. I've noticed that Citroworld sell some also, way more expensive than Der Franzose and if I knew which ones were on this car I'd buy the others, the extra cost isn't that much over the length of time they'll now last. Thanks all.
    Gillian and Chris
    Oh, and a Holden.
    Los Angeles, CA USA
    1,955
    Even the newly made rotors for the DS and SM should be skimmed before installation. I don't know if it is because they get warped in shipping or if they have been on the shelf too long before we buy them. So budget for that before you tear into the project.
    As an aside to metallurgy here, the cars were delivered with hardened rotors at the beginning up to the first few years of 5 main production. I know that 66-68 parts cars nearly always yield a set of hardened rotors. You can't hardly cook them and they never wear out. I think the change to softer metal came about the same time as the big valve head. I know the DOT here in the USA wanted "consumable" parts so the manufacturers could sell more product. I mean, who would want a car where parts didn't wear out? And you certainly cannot have oil in the brake system. This led to the softer rotors which do tend to last forever only if the car receives a period caliper overhaul and the parking brakes aren't abused.
    addo and Lasya like this.
    8,184
    Quote Originally Posted by Lasya View Post
    Make contact with Darrin at Citroen Classics UK, they not only sell parts but actually work on the cars. Darrin often states on his website his opinion of the parts available for sale. That is to say, he has first hand experience with the various suppliers and will honestly rate parts.
    With regard to the pads, have your removed and inspected for traces of LHM? Not always obvious on a cursory inspection without removal - the symptom is most noticeable when coming to a standstill, a shudder and growling sound.
    Lasya likes this.
    Jan 2015
    A comfy place.
    319
    I've sent an email to Darrin, thanks Chris.
    Of course I'd like these machined, but this is a problem with them mounted inboard.....
    I've heard someone made a jig that could do them on-car. Is this true anyone? How hard is it to make one?
    Thanks,
    Gillian and Chris
    Oh, and a Holden.
    Ici.
    2,560
    tear em out! its a pain in the arse but that would be easier than trying to sort them on the car SURELY?
    Lasya likes this.
