Left Blower stopped working D Special 74
  • 1 Post By fritzelhund
Thread: Left Blower stopped working D Special 74
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    Default Left Blower stopped working D Special 74
    Is there already a thread on this? If not, I've done the percussive maintenance thing suggested by Bauke and Lance (Collins - Well met Lance good luck in Targa and hope you're the first Citroen home!!!) but the smacks haven't helped. It's getting power, but I'm unsure of the method of its stopping. One day it was working and the next it wasn't. I don't know if it failed while working or just turned off never to re-start. I'd like this one working to de-mist the windscreen...
    Thanks in advance
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Mar 2005
    877
    Quote Originally Posted by Lasya View Post
    Thanks in advance
    There are a couple of different suppliers. One type has a quite open motor casing that can just become dust filled which stops any movement of the brushes...that is why a smack will sometimes help. These things are easy to remove and inspect...failing its complete demise a good clean and maybe new brushes might do the trick. Easiest to remove the whole heater assembly and pull apart on a bench.
    Lasya likes this.
    Jan 2015
    A comfy place.
    319
    As I thought, I might try with a blast of compressed air in the general direction of the fan.
    Gillian and Chris
    Oh, and a Holden.
    Ici.
    2,560
    could be doyty or loose connections too huh?
    Jan 2015
    A comfy place.
    319
    Nah, checked circuit, everything fine.
    Gillian and Chris
    Oh, and a Holden.
