Weird Marchal points DS23..... Need help, advice, parts.....
Like Tree3Likes
  • 1 Post By citroenut
  • 1 Post By Roger Wilkinson
  • 1 Post By jonf
Thread: Weird Marchal points DS23..... Need help, advice, parts.....
    Jun 2012
    north fitzroy, victoria
    191
    Default Weird Marchal points DS23..... Need help, advice, parts.....
    Have bought Hoogys DS23 carby 5 speed
    need points.... Never seen a set like these before....
    Marchal D type #5482145 is part number....
    anyone got a local supply? have found a set in UK but if local available would prefer.....
    And next option.... Can I just swap for a normal distributor and solve problem that way?
    jon
    Apr 2016
    San Isidro
    7
    I dont think those are regular marchal points, I believe you have electronic points convention
    Coffs Harbour, NSW, Australia
    626
    They look like the Marchal cassette point set. I've not seen them on a D series but they were often found on the GS with Marchal distributors.
    If it were mine, I would search out at least a transistor conversion to prevent wear on the points, or a full electronic replacement with a 123 distributor & never have to reset & retime the ignition again.
    Richard
    JohnW likes this.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,405
    Jon, they are standard cassette points. I had a DSuper with them when I in NZ in the 1990s. They work fine, just drop in and you can adjust them (with an Allen key from if my memory is right) from outside the distributor. Ask around the usual suspects, they ought to be available. No need to replace the distributor.
    Roger
    addo likes this.
    Jun 2012
    191
    i have learned they are called ' cartridge' points... i put a photo on.... my cartridge is snapped off internally - deep inside the cartridge there is a small fibre board that locates the spring to move the points with the shaft cam... it has broken right through on the rivet so there is zero spark going thru. Bauke the wizard was here today and has swapped the entire Marchal distributor for a Ducellier off a DS23EFI that i had in my junk pile... it has at least got the car running although the condenser and the ballast resistor are both shot too !!! but i would like to get it back to original eventually..... have located the correct cartridge in uk and failing any local supply will get them sent. car is running but rough.... plenty to do before it can get back on the road. cheers, jon
    okalford likes this.
    Oct 2003
    Hampton Park
    523
    My D special has the cartridge
    I obtained a spare from the UK
    Not that costly about $30
    I used to run transistor triggered ignitions years ago.
    for an occasional car they are basically a waste of time
