Xantia Aerial Removal
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By Richard W
  • 1 Post By JAJEA
Thread: Xantia Aerial Removal
    Apr 2013
    Essendon
    699
    Default Xantia Aerial Removal
    Anybody know how to remove the aerial off the Xantia?
    I was quite happy to simply lay it down so that I could put a tarp over it.
    Got to the stage where I as about to get the 1\2 " drill to get that plug off!
    John
    11,232
    The long bit screws off the base where black meets grey and they fold down onto the roof too.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Apr 2013
    Essendon
    699
    Thanks John.
    I've ripped the skin off my hand trying to unscrew it!
    Time for multi grips I guess!
    1000+ Posts Richard W's Avatar
    May 2012
    1,377
    Doesn't the base unscrew from underneath?
    Sent from my iPad using Tapatalk
    addo likes this.
    11,232
    Quote Originally Posted by JAJEA View Post
    Thanks John.
    Ouch. That's my recollection anyway. Ooo...
    11,232
    Quote Originally Posted by Richard W View Post
    Doesn't the base unscrew from underneath? Sent from my iPad using Tapatalk
    From underneath the headlining in the interior, presumably it does......
    May 2012
    1,377
    In a 205 that screw is easy to get to - all you do is unclip the interior light. Is it perhaps the same in a Xantia?
    11,232
    I'll stop guessing and find the manual!
    11,232
    Haynes confirms stalk unscrews. Also says roof lining removal "best entrusted to a Citroen specialist" is needed to get at the securing screw for the base. Just a small removable plug would avoid such misery, but another production cost of course.
    Apr 2013
    Essendon
    699
    Thanks John, I expected it to unscrew as it must be removable with auto car washing facilities and I want it removable for covering purposes - certainly not touching inside lining!
    Multi-grips are looking good notwithstanding I'll try a bit of WD40 and give it time to work.
    John
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,241
    Xantia Aerial Removal-image.jpg I unscrew ours regularly, but remember it did take a bit of effort the first time. This is the '96, which unscrews easily; the '99 feels more ratchety when it it is unscrewed.
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    Apr 2013
    Essendon
    699
    Thank you all and thank you Bruce for confirming the obvious,
    Multi grips at the base (with protection) did the trick.
    Whilst there is a very good seal between the two, there was some evidence of some very minor corrosion. Cleaned and lubricated threads with WD40 - it will be easy from now on.
    John
    Quote Originally Posted by Bruce H View Post
ID:	82544 I unscrew ours regularly, but remember it did take a bit of effort the first time. This is the '96, which unscrews easily; the '99 feels more ratchety when it it is unscrewed.
    JohnW likes this.
