73 SM EFI Restoration
Results 1 to 9 of 9
Like Tree3Likes
  • 3 Post By citroenthusiast
Thread: 73 SM EFI Restoration
    Apr 2014
    Phoenix, Arizona USA
    699
    Default 73 SM EFI Restoration
    Not sure if Hemmings gets much circulation down under, so here is a shameless plug for the restoration I just finished:
    The Mother of Invention - 1973 CitroŽn SM | Hemmings Motor News
    GreenBlood, 59 Floride and JohnW like this.
    John T.
    Ici.
    2,652
    that's noyce mate! choyce! Especially the lamps.
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    The hardest part of reading a wonderful SM story is - i want one
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
    CitroŽn Tragic UFO's Avatar
    9,786
    Well done! Brag all you like
    11,220
    We drove through Phoenix a few years ago. Missed it!! Lovely, as ever, and I will always want one.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jul 2011
    Ingoldsby,QLD,Aust
    491
    omg.......that is gorgeous! It really is
    Sydney, NSW
    427
    How stunning. I love those wheels. Really nice restoration. Chris M
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,046
    Citroenthuiast, Well done
    You have obviously put an aftermarket ECU onto this engine. How does it time when to do its fuel injections? Does it control ignition timing as well or is that wholly handled by the substitute distributor? If the ignition timing is ECU controlled, how has the crankshaft sensor been mounted so it knows when to oddfire?
    Cheers, Ken W
    Apr 2014
    699
    The ECU controls fuel only. It batch fires the injectors (just like the D-Jet did) based on the tachometer signal. The Pertronix ignition module handles the spark, but otherwise the distributor is stock (except there was no need for the SEV D-Jet trigger points). The Microsquirt ECU could have handled ignition timing, but that would have required modifying the distributor to lock out the flyweights (e.g. welding things together) and, with the odd fire engine I still would have had to settle for batch fired injectors. It is possible to get full sequential injection and ignition timing control, but to do that you need to mount a 36:1 sprocket on the jackshaft. That of course is not as accurate as a flywheel sensor, so to really do it right, you need a sensor on the jackshaft (for TDC #1) and a crank sensor, both of which would be visible and difficult not to look homemade.
    John T.
