Bill, HRE, your opinion please :)
Results 1 to 25 of 35
Like Tree8Likes
Thread: Bill, HRE, your opinion please :)
    8,249
    Icon3 Bill, HRE, your opinion please :)
    Bill,
    Have a look through this thread
    Citroen-Forum.nl - Citroën ID/DS - Spanningregelaar ombouwset voor wisselstroomdynamo
    You'll probably need Google translate
    This appears to be a perfect modification for the Ducellier regulator fitted to the D. From what I can make out this unit fits neatly into the original housing and allows for the dash light in the circuit. It also appears to be suitable for BVH cars.
    The US supplier
    Voltage Regulator
    Ebay
    Alternator Voltage Regulator Universal 12 Volt B Circuit ONE Wire | eBay
    Your thoughts
    08 C5 X7 HDi very Noir
    Ici.
    2,655
    Are they trying to flog off worn out faulty Chinese pacemakers Chris? No seriously they'll be walking out the door now!
    It's how I roll...Brisbane
    33,721
    Meh! It's all been done before..
    8,249
    Quote Originally Posted by 59 Floride View Post
    True, but I've not seen anything that appears to be a straight swap into a D regulator, allowing the dash light and starting on a BVH car. . . currently (hahah pun) the suggested conversion is a Bosch RE55 but it needs several modifications.
    Interested in what Bill has to say
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    437
    I got me a brand new Hella (5DR 004 243-051) for all of €21.95 from a reputable vendor (not on ebay) which would fit into the Ducellier box except I didn't bother to do it, and whereas my battery was whining, whingeing and constantly trying to kill itself, it is now very happy and healthy.
    I know because I have a volt-ammeter.
    The light, it's only a matter of reading the voltage on the small stud on the alternator and using a small relay/transistor - which will also fit inside the box - to pilot it.
    8,249
    Quote Originally Posted by Don B. Cilly View Post
    Yup, I've seen that conversion too Don. The difference here is that the American unit appears to be a 5 wire all in one solution, no add ons, just solder in place and you have a solid state regulator with dash light, and the ability to be used on a BVH car.
    Bill (Hotrodelectric) has turned in for the night but will give an opinion when he's had a chance to have a good look.
    San Diego, California, USA
    3,543
    Hi all- looks like I'm late to the party once again.
    This regulator isn't much different from John Titus' or Mark Bardenwerper's idea with the Ford regulator inside the original can. The only snag I see is the light trip is nor going to be strong enough for a BVH start circuit. I think you can have a relay from the light circuit to do the start function if you like. The overall hookup is pretty simple, and hiding it inside the can would be a doddle. There is one point that concerns me, and that is the B+ connection. I don't know if that's a battery connection, or an ignition connection. It would seem to me that a battery connection would have the regulator switched on continuously. I'm emailing these guys to find out for sure.
    On the whole, I think it's a terrific idea. Think stable lighting in a far smaller, cheaper package.
    GreenBlood likes this.
    3,543
    Alrighty Chris- I've gotten a chance to email them with a couple of questions and clarifications from when I contacted them this morning. I should hear back within a few days.
    19,211
    If I may interject here?
    Here is Dr Hugo Holden's solution to a dynamo regulator to replace the Lucas RB series units as fitted Triumph TRs.
    It's an elegant and straightforward approach and equally applicable to Citroen regulators.
    And the cost saving of doing the work yourself should be considerable.
    http://www.worldphaco.net/uploads/LU..._REGULATOR.pdf
    JohnW and Hotrodelectric like this.
    8,249
    Thanks Bill,
    This info is more for others as I have opted for a 100amp alternator with internal regulator. Although who knows one day I may have a BVH in the stable haha.
    Just a couple of points, in the above NL link it describes B+ as connecting to BOB on the 'can' so I presume that means ignition switched?
    This appears to be the same set-up by Delco - if brand names mean anything.
    Part # D7024 - Conversion Voltage Regulator 12 Volt, B-Circuit, 14.2 Voltage set point. For: Universal Design
    3,543
    Thanks Bill,
    I'm betting the rent it is ignition switched. B+ doesn't make a lot of sense to me, but the quick and dirty diagram they show on the website says "B+", which to me means battey continuous. I'll go have a look at the one you link. It's probably basically the same thing, looking at the description.
    I was wondering when you were going to show up
    I'll go have a look at that one too. You ain't far wrong. DIY on something that comparatively easy saves a lot of money. Even better if this one is already available for you guys like the original Ford-in-the-can solution was for us.
    3,543
    That looks like the exact same one. I know the seller- he's a bit on the expensive side, but the stuff is good. I think 50.00 US a little high, but then I think of the cost for an NOS Ducellier or Paris Rhone regulator. All of a sudden, that 50.00 looks positively cheap.
    8,249
    [COLOR=#333333]
    There are a number of posts on OS forums where the fail rate of NOS and rebuilt Ducellier/Paris Rhone regulators makes them a lottery with a short fuse. . .
    Getting a solid state external unit that hides inside the 'original' box, and is an easy installation for the layman is proving to be the challenge. Rob's link had my head spinning, for those with the knowledge required it probably is a thing of beauty but no way I could put it together (and would it fit inside the original box. . .)
    3,543
    I had a quick look at your find. At first, it mentioned TR4, so I'm immediately thinking "positive ground". Wrong there, so I had a look at the hookup diagram. Come to find out that it's for a generator, not an alternator. Damn elegant solution though. Quite useful on the pre-'66 cars. I'll understand it better once I read the entire article.
    11,231
    Elegant indeed. Top end Bosch quality, that item. Almost wants me to get a 12V car with a generator. Almost........
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    19,211
    To be 100% correct both Alternators and dynamos are generators. Ie they generate electricity.
    I know it's subtle difference. But old timers will always refer to " auto generators" as dynamos. I had this terminology implanted into me, by the then Chief Engineer or Jo Lucas Australia, A mate of my brothers. In fact I did holiday work experience at the Chelterham Plant courtesy of the connection.
    May 2013
    171
    .... I had this terminology implanted into me, by the then Chief Engineer or Jo Lucas Australia, A mate of my brothers. In fact I did holiday work experience at the Chelterham Plant courtesy of the connection.
    Wow you know the "Prince of Darkness" personally
    Seriously that would have been a very interesting experience
    Peter
    1950 11BL
    1970 AZUA "La Poste" van
    1986 2CV Dolly (red and white)
    2004 C5 HDi silver 2.0L
    19,211
    Quote Originally Posted by Peter O View Post
    Actually it was very interesting. With CE's insight I learnt all about the issues of putting design into a production line. And saw examples of workers stuffing up assembly in every possible way. And the problem solving to make assembly idiot proof. A primer in production engineering if you will.
    Also how engineering design is compromised by penny pinching a few cents by not putting field diodes in a plastic support with some epoxy. But accountants will be accountants. This design fault end up costing Lucas the Toyota and GMH contracts. Because the alternators were failing just after warranty expired.
    Engineering proving dept knew of the fault and the fix but the implementation was refused by the bean counters. Because the product was on contracted price to the car manufacturers.
    I also saw Lucas engineers implement the plastic battery line. Which was a 100% Australian designed and built product.
    It was an interesting workplace with a smattering of Poms and Australians in management and the workforce.
    And the (covert) destructive tests of Bosch and Nippon Denso products and the analysis of the failure modes. This is where I developed my respect for ND products which easily outlasted any other product by a factor 5.
    Dano likes this.
    Apr 2013
    Essendon
    699
    Ahh Nippon Denso is a name that I never heard of in OZ until I worked on the Toyota Crown line in AMI Port Melbourne (in between Uni years or was it post uni awaiting an engineering job?) some 45 years ago. Everything electrical was Nippon Denso!
    John
    3,543
    Point conceded. Here we see them as generators and alternators.
    11,231
    Me too, all my adult life. Then there's the "really old" old-timer's "dynamo", which I'd always used for my bicycle.
    3,543
    OK, getting back to the question I posed for the seller.
    The B+ wire does go direct to battery. That means a couple of things: 1) That is a volt sense lead. 2)The light wire is what controls the regulator. Going further, you MUSm without fail ensure the charge lamp circuit works, or else you will not charge. This depends on differentiation between the either side of the charge lamp to work. Checking is simple. Merely touch the factory light wire- the one sleeved in red- at the regulator to ground and see if the lamp works.
    Hookup is simple past that. The field wire goes to where the yellow sleeved wire is. The one marked "Ps" will go to the post with the white sleeved wire. The "BOB" wire- 6.3mm spade in purple- is disconnected and folded away. You can use this one to trip a small ignition on circuit. The black wire is ground. Ensure that ground is solid. All the years of rust, corrosion and dirt at the battery holddown is bad ju-ju.
    I hadn't thought about it much, but with this regulator you won't have easy access to a switched ground for the starter anti-repeat on a BVH car.
    11,231
    Really interesting, thanks. Somewhere out there there's a really good article on the decline of Lucas quality, of which your description is a simple, individual example. Lose customer respect and...... Pity they couldn't put the destructive test results to good use.
    3,543
    Yah, Denso is still a high profile name for electrical stuff. I see it in one form or another on virtually every Japanese car I have ever seen.
    8,249
    hmmm, "Are we there yet, are we there yet. . . "
    Seems not, is there a simple workaround for the anti repeat on BVH cars?
