Boot keeps opening on C5
Results 1 to 15 of 15
Like Tree12Likes
  • 2 Post By Buttercup
  • 3 Post By Stuey
  • 3 Post By DoubleChevron
  • 1 Post By dieselman
  • 1 Post By JBN
  • 1 Post By dimistyle
  • 1 Post By KimHowe
Thread: Boot keeps opening on C5
    Mar 2016
    Bundaberg
    1
    Default Boot keeps opening on C5
    Hi Everyone.
    I am having trouble with my wifes C5 II 2006 Hatch. The boot keeps on opening when we unlock the car or open a door. It is intermitant but constant. I have been doing some reading up on it and it could be a micro switch in the central locking boot catch. The other idea could be that the BSI has gotten scrabbled and it needs a reset. I have instructions on how to do this manually. Does this look right??????
    To perform the reset;
    1. Put the drivers window down and lift the bonnet (leave the key in the ignition)
    2. Ensure all equipment (stereo etc) is switched off
    3. Ensure all doors are closed and reach through the window to remove the key from the ignition
    4. Wait 3 minutes
    5. Disconnect the battery and then wait 15 seconds
    6. Reconnect the battery and wait 10 seconds (Do not open any doors)
    7. Switch on the ignition (but don't start the engine) and check that all tests pass
    8. Hold the lock button on the key down for 10 seconds
    9. Remove the key, open the drivers door, close it and check the central locking works (I had to hold the lock button down for another 10 seconds at this point)
    10. Start the engine and complete the systems check
    Note: When you put the drivers window up, it won't automatically go all the way up. Make sure you close it all the way before putting it down, otherwise the automatic close won't close it all the way until you next turn the ignition on and off
    Has anyone had similiar problems with their Citroen ?
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,048
    I'm not sure if this is correct but it sounds similar to a sequence I saw in an article in our CCCQ club mag recently. AF should store all these setting sequences somewhere for future reference. The one for resetting the accelerator pedal is another one that is reputed to improve drive-ability considerably.
    Over to the C5 experts.
    Cheers, Ken W
    Fellow Frogger! Buttercup's Avatar
    Jan 2013
    Lake Keepit NSW
    818
    Gosh.......... I read that reset sequence.... and can't stop laughing!
    Its totally beyond my comprehension that anyone wants a computer in a car.
    I love my carby, points and window winding handles...... Oh hang on, the 2CV hasn't got window winding handles.
    But then it hasn't got a radiator, fanbelt, water pump, electric locking, nav, cruise control, turbo or blue teeth either.
    It does have central locking.... I can reach all the door locks from the drivers seat.
    Back to your erratic boot. I could post you a roll of silver/grey tape!
    shanadoo and JohnW like this.
    Bob
    '57 Slough DS19, Buttercup
    '60 2CV 1220, Raid Runner
    Several DS19 and 2CV projects
    Don't remind me!
    16,609
    It could also be a sticky button on the remote if it has a separate button for boot release. Sometimes the rubber swells up and does not release contact with the conductive track on the remote control's circuit board.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Is the cars battery OK. Get it load tested. Computer systems need a very constant power feed
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    6,668
    Quote Originally Posted by Buttercup View Post
    But can you do it from OUTSIDE the locked car?
    (Stuey struggles to think of the only 'benefit' to the technology...).
    jaahn, JohnW and shanadoo like this.
    2003 PEUGEOT 206 GTi
    10,128
    The boot opener is a pressure contact switch and it can play up in old age. That's possibly the most likely cause of the problem, but don't forget the wire bundle can fray between the body and tailgate. Slip back the boot and check for any frayed wires. A dealer will have seen this before so avoid paying to retrain the local auto-electrician.
    10,128
    ... and from a distance!
    It's a neat trick to have the auto-open tailgates on later wagons when shopping.
    16,717
    I dunno ... my kids were amazed at the technology the 1963 ID19 has ...... "LOOK DAD ...... The window still works with the car off" ............ as she slowly winds up the back window
    shanadoo, JohnW and jaahn like this.
    Aug 2005
    Merimbula, NSW, Australia
    323
    My 2006 C5 had the same problem. The plastic piece that you press to open the boot loses its 'spring' and stays in contact with the microswitch.
    I fixed it by disassembling the handle and sticking a couple of pieces of adhesive backed neoprene foam to the inside of the handle which then act as a spring to return it to the proper position away from the microswitch. Once reassembled, you won't see the foam strips.
    It worked at treat!
    Buttercup likes this.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    Jan 2013
    Lake Keepit NSW
    818
    There's nothing like a bit of sticky foam to fix technology designed to last 5 years......
    Although I'd expect to replace the fix every 5 years too.
    Bob
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    Maybe the boot is hungry. Why don't you feed it with suitcases?
    John
    Peter O likes this.
    Aug 2016
    Sunshine Coast, QLD
    935
    Just spoke to a friend over the weeken who picked up a face lift C5 3 months ago, and this is her problem as well, some weeks she has no boot unlocking other times the boot opens every time......I'll check her boot opener handle and see if she needs the sticky foam treatment.
    Great reading old threads for simple fixes.
    dieselman likes this.
    Mar 2016
    Mole Creek Tasmania
    64
    My C5 Wagon (now retired to the private wrecking yard) had a similar issue. It was caused by a broken piece in the plastic surround near the button. The button could get stuck behind the plastic surround. This would result in odd things like the boot unlocking when you opened a door or started the car - which is simply because that's when the computer checked the switch. Worth having a look.
    dimistyle likes this.
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    467
    I have a C4 coupe series one that has started doing the same boot opening antics accompanying the unlocking of said vehicle and opening of doors. Sounds like the tailgate switch has a similar problem. My remote is relatively new as i replace the case every couple of years.
    Sent from my SM-T113 using aussiefrogs mobile app
