DS IE Fuel Rail Finish
Results 1 to 23 of 23
Like Tree2Likes
  • 1 Post By Hotrodelectric
  • 1 Post By badabec
Thread: DS IE Fuel Rail Finish
    Apr 2013
    Essendon
    699
    Default DS IE Fuel Rail Finish
    Any ideas welcomed
    Fuel rail is out for a complete refurbishment to eliminate fuel leak that would not abate despite retightening hose clamps.
    After cleaning the rail, it still looks shabby and was thinking / wondering what others did. - Anybody chromed / cadmium plated / painted theirs?
    By the by, the whole EFI hose installation was relatively new (Gates EFI 5/16") with correct TRIDON EFI hose clips. [Installed I believe by Lance of DS Motors.] These are not the standard worm drive units. Regretfully there was no evidence of any of hoses attached to the rail leaking. (Nevertheless, I have purchased 2 packets of non worm drive clamps so I'll be using them.)
    I now believe that the leak was on the return line short hose attaching the D's return line from the centre fixed pipe under the Fuel Regulator.
    First venture under the D's bonnet - I did not now it was there.
    Another question arises - is there any need for the fixed centre pipe? Has anybody eliminated it?
    Your thoughts would be appreciated.
    John
    Apr 2013
    Essendon
    699
    PS: Note the repairs on the front rail at the attachment via a pipe clamp!
    There was no protection given to the rail as it passed through the clamp and hence there was evidence of another leak about to happen as the rail pipe was peened flat. This was attended to and the rail pipe will be protected on installation. (Maybe the clamp had at one stage rubber protection but fell off in the last 40 odd years and not replaced.
    John
    Quote Originally Posted by JAJEA View Post
    Any ideas welcomed
    John
    San Diego, California, USA
    3,543
    As for finish, cad plate would be my guess. Painted would look OK if the car weren't going to be run much. Paint is fairly fragile when applied to tubes, though. You could do powder coat if you go the painted route. Chrome is actually quite thick (copper plate, nickel plate, then chrome), I would be worried about what happens inside the tubing. Well done chrome would be some added bling.
    Don't remind me!
    16,609
    I wondered if they were bundy tube with a copper flash over the top. The other possible explanation of how they look, might be just the bundy tube finish but stained by fuel over many years.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    350
    Every time I see the fuel piping on a D EFI engine I think wasn't it a shame they hadn't thought of doing a neat fuel rail design back then to make it less of a fire hazard.
    I looked into it once because you can get extension pieces that fit on top of fuel injectors that then clip into a fuel rail, which would allow just one fuel hose connection and one jubilee clip. But the geometry of the fuel injectors in relation to the inlet manifold pipes complicates matters; the best I could think of way back when was to make two fuel rails for each pair of cylinders, but that wouldn't tidy things up much. If someone out there could come up with a suitable design I reckon they'd have a good little mod for EFI owners.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Jul 2013
    Stamford, UK
    350
    It looks like Othello cadmium plates his DS 23 IE PRESTIGE RESTAURATION INT…GRALE 06. | Citrothello
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2013
    Essendon
    699
    Thank you all.
    Cadmium plating is the way to go.
    John
    PS: And I'll utilize the centre bracket as per original.
    Apr 2013
    Essendon
    699
    Anybody know of a cadmium plater in the northern suburbs of Melbourne. Plenty of Nickel and Zinc can do but unable to locate Cadmium platers.
    John
    Thank you all.
    John
    Don't remind me!
    16,609
    It's really uncommon now, the closest look is yellow passivate on zinc. Maybe there are US shops who can do it? HRE or Daffy will have an idea.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,853
    Appears it has been phased out because of environmental concerns with the process. Still appears to be used in the aerospace industry.
    Why has cadmium plating of fasteners been banned?
    Every day is a good day
    3,543
    California is exceptionally tough on that. This state has decided that damn near everything causes cancer to some extent, and pretty much all our heavy industry, including aircraft has left. I'll have to look around a little and see. What you may do is go to Hemmings.com and look through the services offered pages. I just happened to think, there might be a few platers left in Texas and Washington. Those two states still have an aircraft industry.
    3,543
    addo likes this.
    Apr 2013
    Essendon
    699
    Once again, thanks for your input.
    No doubt for cadmium plating to be still available to the aviation industry I'd consider it to be the superior coating. However, all I desire is something a bit better than the original unfinished fuel rail.
    I'll be chasing local nickel or zinc platers on Monday as I'm keen to get the D mobile again.
    Best regards,
    John
    Apr 2014
    Phoenix, Arizona USA
    699
    Believe it or not, Burbank Plating in of all places Burbank, California, USA will still do cadmium plating, although I have found that the hexavalent chromium yellow zinc is a pretty fair approximation of that wonderful gold color. Beware, however, other "yellow zinc" treatments that do not use the toxic hexavalent chromium are not much yellower than clear zinc.
    John T.
    3,543
    Quote Originally Posted by citroenthusiast View Post
    John T.
    Thanks for that, John. I had forgotten completely all about them. Last time I needed plating services was during my time at Vintage Restorations in North Hollywood. That was a long time ago.
    Apr 2013
    Essendon
    699
    Picked up my Fuel Rail Piping today.
    Quite happy with the bits- best AUD25 I've spent for a while. I had a choice of "finishes", I chose blue zinc [nothing blue about as far as I'm concerned].
    Anybody in Melbourne Australia interested it was - Coburg Plating P/L 3-5 Warner Street Coburg.
    John
    Best regards,
    John
    3,543
    An excellent result, John. That will look good for a long while.
    Apr 2013
    Essendon
    699
    Agreed, I just could not reinstall as is/was, irrespective of how hard I tried to brush clean them.
    Feb 2012
    Ongar / England
    868
    Especially once you've painted them
    addo likes this.
    Apr 2013
    Essendon
    699
    Paint?! I was considering a paint coating if I could not get the plating at a reasonable price nevertheless, what colour would you suggest and what type that is fuel resistant in a spray can?
    John
    Quote Originally Posted by badabec View Post
    Apr 2013
    Essendon
    699
    Yes I have painted them!
    As a result of looking at the refurbishment of the IE manifold possibilities, I went a stage further and coated the fuel rail also.
    Coating is a Dupli-Color High Heat Ceramic (Aluminium)! Magic stuff. Upon coating, put in oven at 200 degrees C for one (1) hour and allow to cool (not when the wife is around - foul smell on curing that lingers for some timAttachment 82634Attachment 82635e!) [And the next time she goes to use the oven!!]
    John
    John
    3,543
    (not when the wife is around - foul smell on curing that lingers for some time)
    What- are you afraid of a little consequence? Hmmmm??
    The pics show up as invalid attachments.
    Apr 2013
    Essendon
    699
    Good afternoon Hotrodelectric,
    No - not at all, just concerned for other AF's, what I get away with is no measure of what others have to go through.
    My wife was home and baked a cake the following day; however she had to clear the smell before baking by cranking up the oven to its maximum and "cooking" the remaining traces of the paint out of the oven linings!
    DS IE Fuel Rail Finish-img_4604.jpgDS IE Fuel Rail Finish-img_4605.jpgDS IE Fuel Rail Finish-img_4606.jpg
    The photos did not previously attach (I think) because of their size, so I removed one and maybe that will help.
    John
