TA starter to 12v
    Jan 2016
    Montevideo /Uruguay
    16
    Default TA starter to 12v
    Good morning:
    How can I take out the starter on the TA? It doesn't go under the manifold ...
    BTW I'll switch to 12v: Will I need to rewire the starter?
    Thanks!
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,156
    Two options:-
    1 Release the rear engine mount from inside the firewall and jack the motor!
    2 Remove the engine manifold.
    The 6 volt starter will spin very well on 12 volts, but as you have found it does not come out all that easily due to its larger diameter. A 12 volt Lucas starter is easier to remove and refit. You would need to rewire a solenoid system to operate it unless you can obtain a prewar version with the cable pull switch!
    Cheers Gerry
    Jan 2016
    Montevideo /Uruguay
    16
    Gerry: thanks a lot. I think it will stay for a while like is
    Cheers, Zeque
    Apr 2014
    Phoenix, Arizona USA
    699
    Or if you want, you can get one of my 12V gear reduction starters for T/A and 1911cc DS/ID. Weight ~5Kg :-)
    John Titus
    Jan 2016
    Montevideo /Uruguay
    16
    Thanks John, we are so far away that shipping count a lot $$ to me :-(
