Finally ... Repairing a traction gearbox. - Page 5
Page 5 of 6 First 123456 Last
Results 101 to 125 of 127
Like Tree33Likes
Thread: Finally ... Repairing a traction gearbox.
  1. #101
    16,151
    OK, dumb question time ... Is there an easy way to measure the pinion depth. I can't be as easy as somehow getting 1.7mm of feeler gauges "somehow" down between the pinion and gearbox casing can it I may need to chase up a dial gauge maybe ( I bet my grandfather has 1/2 dozen of them in his shed somewhere).
  2. #102
    Apr 2014
    Phoenix, Arizona USA
    597
    No. Pinion depth refers to an engagement distance that is measured between the centerline of the crown wheel shaft and the face of the pinion. There is no "space" to measure with a feeler gauge. This is a critical dimension if you want your crown wheel to last. I made up a tool (for DS and SM transmissions) by drilling a hole through the center of a piece of 80mm diameter precision ground shafting. Then I tapped a hole on the edge to thread in a dial gauge. Setting the shaft on a glass table with a 20mm gauge block lets me "zero" the dial indicator at exactly 60mm (shaft is 40mm radius + 20mm gauge block), then I can take the pinion depth measurement.
    John T.
    54 TAV Legere; 61DS19 LHM BVH (son's); 71DS21 BVH; 73SM 3.0; 73SM EFI (Megasquirt); 73SM 3.0 (other son's)
  3. #103
    10,259
    Elegant! That 80 mm shaft sits precisely where the differential would fit I presume?
    I've just been looking at a set of the original factory tooling for setting up Renault 4CV transaxles, which a friend in Paris uses for rebuilding units to new specification. Doing this crownwheel and pinion setup from scratch is not to be taken lightly, is it?
    Fascinating thread.
    citroenthusiast likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
  4. #104
    Apr 2014
    597
    Yes, the O.D. of the carrier bearings for the DS and SM transmissions are 80mm, so the 80mm precision shaft sits exactly on center in the transmission case. I don't know what the dimensions are for the T/A or 4CV, so adjust the dimension accordingly.
    JohnW likes this.
    John T.
  5. #105
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,931
    Quote Originally Posted by citroenthusiast View Post
Name:	Bevel Pinion Depth Gauge.jpg
    There is plenty of space on a traction. The feeler gauge stack of 1.7mm in Shanes case can be slipped in the aperture of the case quite easily an slid between the pinion face and the rectified diameter of the diff. 55mm +1.7mm =56.7mm the distance engrave on that pinion face. Other pinions will have differing conic depth measurements. No need here to mess around with dial gauges and custom made supporting fixtures. Just aim for a feel on the gauge that gives a slight drag . If your gauges are clean the measurement will be dead accurate. I have done this procedure many times.
    DS/SM GS gearboxes are quite a different kettle of fish ----a dial gauge is essential in these cases!
    For a traction, refer to plate 35 and 35a of the Drawings Section of the workshop manual!
    Cheers Gerry
  6. #106
    16,151
    Oh, I think I know the diagrams you mean. I must have scanned a photocopy when those manuals were scanned, and I can't make out what the pinion depth diagrams say. I'll take another look ( and see if I can download a better version of the manual from somewhere).
    seeya
  7. #107
    16,151
    Look what Gerry just sent me .... No wonder I'm scratching my head. The manual I'm looking at is missing several pages by the looks of it (either they weren't in the manual I scanned, or I stuffed up printing them way back when I printed the manual).
    I'll chekc the manual CD's when I get home and see if these diagrams are on it.
    This will make sense if I post the picture from earlier on in this thread. See the pinion depth in scribed onto the pinion from the factory. 56.7mm
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-traction_pinioon.jpg   Finally ...  Repairing a traction gearbox.-pinion_taction_2.jpg
    badabec likes this.
  8. #108
    Apr 2014
    597
    So basically the T/A differential has a 110mm machined surface you can use as a reference. That is convenient. Saves use of the 2044T apparatus.
    John T.
  9. #109
    2,931
    There you have it! Tractions are just bloody brilliant!
    Cheers Gerry
  10. #110
    16,151
    Gerry would have a good laugh if he saw me trying to check that last night... It took me about 1/2 dozen attempts to assemble the pinion shaft in the case before I ran out of time....
    Here's some tips ...
    -Don't fit any of the gears backwards ... or you'll be pulling it back out ( )
    -if you realise you haven't fitted the speedo drive ... don't pull it back out ... you dont' need to ( guess when I realised this)
    -don't think on the 3rd attempt "oh refit the front bearing with the shims while the shaft isnt' there in the way"............ Yep, you can't get the last gear back onto the pinion with that in the way .... And ... It sure is a bastard of a thing to get back out. I found I had to remove the shaft and all the gears and give it a whack from inside the housing with a rubber mallet.
    I reckon I'll be very well practiced at assembling/dismantling the pinion shaft inside the casing by the time the pinion spacing is set correctly (given it'll all have to come apart each time to whack the front bearing housing from behind to get it back out to try different shims).
  11. #111
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,191
    You'll be doing it in your dreams soon
    Every day is a good day
  12. #112
    2,931
    I told you that the fun was only just beginning! Once the shaft and gears are in it is not necessary to take the whole thing out again. You only need to remove the front bearing housing and bearing to make shim adjustments.
    btw have you fitted the reverse gear already? Because if you have not you will find it very difficult once the pinion shaft and its gears are in place.
    Fitting the pinion shaft is as follows.
    A. 1st/ reverse cluster loose into the box.
    B. Pinion shaft and bearing in part way from the rear.
    C. Thrust bearing and thrust rings.
    D. Second speed splined gear.
    E. Speedo worm drive.
    F. Third speed splined gear.
    Now mount the box vertically in the vise and lever second splined gear up way from the thrust race.
    G. Slide the half locking collars ( C rings ) into the groove one at a time. You may have to tap the pinion shaft back slightly to let the grooves line up with the space for the collars.
    The second splined gear can now drop down and enclose the locking collars.
    G. Fit the front bearing cage together with a stack of shims and the bearing.
    H. Torque up the front nut and fit the diff slightly firm in rotation . Do not worry about back lash on the crown wheel. A lot of play at the moment is good to prevent the teeth fouling if the conic depth has to be reduced. Fit the lower front bearing cap and torque to specs.
    I. Measure the conic depth.
    J. Now begin making adjustments to the shim stack.
    K. Only remove the bearing cage and bearing to make adjustments.
    Be Patient and extra fussy!
    Cheers Gerry
  13. #113
    16,151
    Oh yeah ... I'm being patient. If I wasn't, this would have been back together 3months ago ... when this thread started. If I can spend a day on it at some point, I should get it back together and done (rather than 20minutes at a time).
    I still haven't pulled the diff apart to see if I need some speedi sleeves.... There is no hurry, the car hasn't been on the road for at least 25years .... What's another week/month/year/decade
  14. #114
    2,931
    At least you didn't start it forty years ago like I did with my 11BL
    Cheers Gerry
  15. #115
    16,151
    Just as well I'm not in a hurry .... Gerry said, get the reverse idler in first .... So I figured I better do that (rather than pull it all back to bits later cos I I've dropped the bearings in the bottom of the box)....
    I noticed there was an inner bearing race/washer.... We'd won't to reverse that one to remove any slop too.
    [img]Finally ...  Repairing a traction gearbox.-p1180887.jpgFinally ...  Repairing a traction gearbox.-p1180886.jpgFinally ...  Repairing a traction gearbox.-p1180885.jpgFinally ...  Repairing a traction gearbox.-p1180883.jpg
    They oil film behind them makes them surprisingly difficult to coax off ....
    That must be an oil feed slot there.... Completelly blocked off. I was looking at the bush thinking I'll need to push it out to clear the oil way ....
    Can you believe that .......... Just as well I'm not in a hurry, I need to order in a bushes for the reverse idler.
  16. #116
    8,068
    Icon12
    I think this thread should go straight to the pool room
    08 C5 X7 HDi very Noir
  17. #117
    2,931
    [img]Click image for larger version.
ID:	88385Click image for larger version.
ID:	88386Click image for larger version.
ID:	88387Click image for larger version.
    One more warning that I forgot about. Have the first /reverse cluster sitting loose on the bottom of the box when you fit the reverse idler. Otherwise you won't be able to get it in later. Remember when you removed it that the reverse idler had to come out first in order to remove the first reverse cluster?
    No need to order a new bush! How about I just provide a spare reverse cluster with a good bush??????
    Cheers Gerry
  18. #118
    16,151
    Hi Gerry,
    I feel bad using all your spare parts .... The bush is only 12 euro + postage.... I'd be happy to pay you the money for a bush though Save me waiting a few weeks for international postage
  19. #119
    2,931
    Well, this is embarrassing! I have just spent the morning looking for a spare reverse cluster, and find that I only have one that is part of a set to make up one gearbox. I was putting this aside to use when I am finally able to purchase a 10x31 CW and P. I had wanted to put together a higher ratio box as a spare. I am sorry Shane but it looks like you may have to order the replacement bush after all.
    Cheers Gerry
  20. #120
    16,151
    That's fine, I'd rather use a new bush either way !!! especially given it's tiny cost!
  21. #121
    2,931
    I agree new parts are always preferable! Are you going to get a new shaft for it to run on as well?
    If you fit this bush to your gear you will have done the one job on a traction gearbox that I have never done! What a way to attain a little one-up-man-ship!
    Cheers Gerry
  22. #122
    16,151
    The shafts looks as new. I'm getting when the tooth went through the gearbox, it brake the reverse idler mounting in the case ... and cracked this bush!
  23. #123
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,839
    Better make sure that the shaft is not bent at all. Sounds like it could have transmitted quite a bit of force.
    Cheers Ken.
  24. #124
    16,151
    Quote Originally Posted by Ken W View Post
    Cheers Ken.
    The shaft would be enormously strong compared to the frail bit of alloy that held it in place I certainly will check though!
    JohnW likes this.
  25. #125
    2,931
    The shafts looks as new. I'm getting when the tooth went through the gearbox, it broke the reverse idler mounting in the case ... and cracked this bush!
    Obviously there is not much wear in the bush as well. The damage must have been caused as you have reasoned! There is the added puzzle of the damage being at the opposite end from the broken lug in the casing!?!?!?
    Cheers Gerry
