Finally ... Repairing a traction gearbox. - Page 4
Page 4 of 6 First 123456 Last
Results 76 to 100 of 127
Like Tree33Likes
Thread: Finally ... Repairing a traction gearbox.
  1. #76
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,988
    Yes This car is really nice! Once the gear box is back together and those few rust issues( very very few!) are attended to she will be good to go for many more miles.
    You should have seen the amount of rust I had to contend with around the boot floor and fuel tank area on my11BL. Basically I had to replace the bottom six inches of the whole rear and remanufacture hinge plates and captive nuts /retaining plates for the boot lid! Lots of fun when all you have is a set of dollys a few panel hammers and a length of six inch I beam steel as your specialist work tools
    GreenBlood likes this.
    Cheers Gerry
  2. #77
    2,988
    Well I'm incredibly lucky. Gerrypro called in for a visit last month. He spotted quite a few issues I had missed. I'll go into these as I get to them (so he can correct me if I'm wrong ).
    Attachment 84944Attachment 84945Attachment 84946Attachment 84947Attachment 84948Attachment 84949Attachment 84950
    This is why Gerry was so concerned I couldn't use that gearbox case. There is actually a whole chunk missing. The bizare bit? It's not in the gearbox anywhere! I wonder if this was broken off many decades ago and ignored
    I did go fishing .... and foudn the broken teeth.... But where is the broken bit of gearbox housing
    Pulverised to paste between the remaining gears! Notice how golden your oil sludge is! It is usually a dark grey!
    Cheers Gerry
  3. #78
    16,247
    That's a possibility! As for rust ... that doesn't look like rust damage. maybe it's accident repair Though both sides are the same. Did you notice there is no wind up vent in the scuttle I think one of the reasons for lack of rust is the scuttle was obviously leaded shut when the car was quite new, so it's never had water leaks into the front floors. The flap and assembly is all still there if you look up from under the dash though. I imagine if anyone wanted it back, they could melt some lead and the flap will re-appear.
  4. #79
    16,247
    When Gerry had a look at these bits... He picked stuff right away.... it took him about 3minutes to find everything I hadn't noticed:
    One of those broken teeth has obviously gone through the crown and pinion.... It's a miracle it shatter the gearbox case. Yes I'd missed this. Note: the damaged hardening (luckily not really in a wear area).
    See the marks in the C shims where the shaft has been rocking ....
    Fortunately he also reminded me I'd need seals .... Lets hope they work. The old Renault 12 had a similar seal ...they were miserable bloody things that always leaked on me. It doesn't look like the existing seals leek though (I don't consider "weeping" leaking though ).
    I also ordered in the missing key way.
    Anyway, I thought I'd start by making this up....
    the bushes are exactly 22mm long. The depth of the area in the gear appears to be 48mm.,, so the spacer needs to be 4mm wide.... I wanted to double check this though.
    The bloody hole isn't centred. If I make that spacer as shown above, I'll block at least 50% of the oiling hole off. What I'll need to do is turn one of the new bushes down by 2mm and make the spacer 2mm wider so it's centred over the oil hole.
    I wonder why the oil hole is off center? Very weird.
    Oh, and the one thing I found "wrong" with this gearbox that I thought would need repair ... Doesn't. That is the slop in the reverse idler shaft.
    This is where the bearings have run against the spacers for the last 60years....
    It looks like just turning the shims around as suggested by Gerry will remove all the slop.
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-p1180789.jpg   Finally ...  Repairing a traction gearbox.-p1180786.jpg   Finally ...  Repairing a traction gearbox.-p1180776.jpg   Finally ...  Repairing a traction gearbox.-p1180775.jpg   Finally ...  Repairing a traction gearbox.-p1180774.jpg   Finally ...  Repairing a traction gearbox.-p1180773.jpg
    Finally ...  Repairing a traction gearbox.-p1180772.jpg   Finally ...  Repairing a traction gearbox.-p1180770.jpg   Finally ...  Repairing a traction gearbox.-p1180765.jpg   Finally ...  Repairing a traction gearbox.-p1180762.jpg   Finally ...  Repairing a traction gearbox.-p1180768.jpg
  5. #80
    2,988
    Don't forget to reverse the thrust rings in the end bore of the reverse idlers as well as the large thrust rings!!!!!!!!!!!!
    Bed the outer parts of those large seals with silicone sealant, and use 'Speedie Sleeves' to rebuild the seal run of the output flanges!
    Cheers Gerry
  6. #81
    16,247
    Gee's this stuff is brilliant.... Id never heard of speedie sleeves until Gerry mentioned them ...
    SKF Speedi-Sleeve
    I bet there fun to press on without damage!.... Actually, I'm going to google that ....
    Gee's how easy is that ... He even started with the sleeve sitting on there on a strong angle and just starts hammering And it didn't destory it!
  7. #82
    2,988
    Have you purchased the 'Speedie Sleeves' yet? They come with a device that assists fitting!
    Cheers Gerry
  8. #83
    16,247
    Finally I've done a little tinkering.
    I'm really hopeless with one of these things ... but we'll get there
    I turned one of the bushes slightly shorter as you can see (to cater for the offset oil feed hole in the gear). The spacer should work ok, but is far from pretty!
    It should work fine though.
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-p1180872.jpg   Finally ...  Repairing a traction gearbox.-p1180870.jpg   Finally ...  Repairing a traction gearbox.-p1180869.jpg   Finally ...  Repairing a traction gearbox.-p1180868.jpg
  9. #84
    16,247
    I wasn't going to bother to pull these apart as I reckoned they felt great ....
    Gerry was sure they would need to come apart. That's his modified center used to install and extract the spring loaded bearings.
    See the bits of metal crap/buildup on the center where I"ve pushed it in out of of the gear a few times.
    The reason I slid it in and out a few times was because I couldn't see how to extract the balls (even though gerry did show me about 10times). Like everything it's obvious once it's apart. I just put it in a ziplock bag and pushed the center out.
    Look at the buildup of metal and crap in there !
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-p1180760.jpg   Finally ...  Repairing a traction gearbox.-p1180759.jpg   Finally ...  Repairing a traction gearbox.-p1180757.jpg   Finally ...  Repairing a traction gearbox.-p1180756.jpg
    FIVEDOOR likes this.
  10. #85
    16,247
    moving along ...
    I assembled the lower shaft ... and there seem to be a hell of a lot of slop in the bottom gear ( assembly instructions say .05 -> 0.2 is permissable). I measure 0.7 with the new C washer in there (which lock it in 100% tight with no rocking).
    So I turned it over and measured between the celeron washer and bearing ... yep, 0.7mm is nice and tight on the feeler gauges.
    the celeron washer in there is ~ 2.5mm .... all of Gerrys spares are a maximum of 2.5mm. Now we should be aiming for a 3.0 -> 3.15 mm celeron washer.
    I'm guessing it's ok to sand two washers down to 1.55mm and use two in the place of one
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-p1180875.jpg   Finally ...  Repairing a traction gearbox.-p1180874.jpg   Finally ...  Repairing a traction gearbox.-p1180873.jpg
  11. #86
    2,988
    moving along ...
    Yes I have done that before. Select two that together are slightly over size Glue them together with Cyanoacrylate and then lap them down to the required 3.5mm using a sheet of glass oil and wet and dry paper 240 should be ok! The sheet of glass gives you a good chance that the washer will remain true in thickness as you sand. Turning the washer through 90 degrees every so often as you go helps to prevent the sanding from taking too much off one side!
    The other approach to reducing the longitudinal play of this gear is to insert a steel shim between the thrust race and the gear face. This approach moves the gear back on the shaft. The previous approach moves it forward.
    Cheers Gerry
  12. #87
    18,195
    I'd face the bush in the lathe every time. Guaranteed parallel (to the limit of the lathe "true").
  13. #88
    2,988
    Hi Rob these are spacers and also act as thrusts. They are made of resin impregnated cloth. It was supplied under the name of 'Celleron'. I think that they might be very hard to mount in a lathe. I did not have access to one in any case and this was the technique that I came up with. It works very well. It would also be possible to turn up a phosphor/bronze replacement.
    Cheers Gerry
  14. #89
    18,195
    Sorry Gerry, missed the fact they were celleron washers.
    I was still in phosphor bronze "mindset" .
  15. #90
    16,247
    Yes, you could never machine that as is. They are far to fragile. As it was, the oil spacer above... I crushed the first one I made in the lathes vice... 2nd time around I made it on the bush, then cut it off when it was finished (so the lathe was holding the full sized bush, rather than the frail turned down oil feed spacer).
    I think I'll sand down two washers to 1.55mm ..... Then glue them together from the faces that have been sanded (that way it should be nicely keyed). I'm figuring any slight out of roundness will be quickly worn away by the hardened gears it runs against.
  16. #91
    2,988
    Choose the washers that already come as close as possible to the desired total thickness when placed together. Then there will not be so much to sand down, thereby minimising any chance of error.
    BTW Celeron when running in oil against a hardened steel is mighty resilient stuff. I would not count too much on the bedding down process to correct any errors!
    Cheers Gerry
  17. #92
    16,247
    Thanks Gerry,
    once again you are right. Interestingly all of the washers vary in thickness by atleast 0.1mm if you run the calipers around them! They stay the same difference in thickness with sanding.
    Very easy to sand down as you suggest. It appears to make no difference to how exact there shape is.
    They are a nifty design with the oil feed embossed into one side.
    As you suggested, superglue easily glues them together ... I only stuck a couple of fingers to them in the process.
    It shows 0.05mm instead of 0.7mm now .... However I know the washer varies in thickness between 3.05 and 3.15 ... So it's within spec ... sort of. Well it's as good as it ever would have been anyway!
    I'm pretty sure the process that embossed the oil way, also narrowed the washer by about 0.1mm in that area.
    Attached Thumbnails Attached Thumbnails Finally ...  Repairing a traction gearbox.-p1180882.jpg   Finally ...  Repairing a traction gearbox.-p1180881.jpg   Finally ...  Repairing a traction gearbox.-p1180879.jpg   Finally ...  Repairing a traction gearbox.-p1180878.jpg   Finally ...  Repairing a traction gearbox.-p1180876.jpg
  18. #93
    2,988
    Good job! The superglued fingers only show that you are really attached to ,this hobby!
    Cheers Gerry
  19. #94
    2,988
    Now comes the real fun part, setting up the shim stack to get the correct conical depth for the pinion. Remember that shim stacks (especially when using recycled shims are compressible. This means that it is no use taking a measurement between the 55mm radius of the diff and the pinion face unless the pinion nut is at full torque and that the front bearing cap is fully tightened. Do not use paper gaskets (ever, they are a source of variation) or sealant (only on final assembly) at this stage because it will all have to come apart quite a few times as you alter the shim stack. You will need to include the forward gears and speedo worm on the pinion shaft, and as it is odds on that you will not have the stop tool to immobilise the shaft and gears, a good substitute can be improvised from a socket resting against third gear and the casing with a large screw driver against the socket and the blade held firmly between the teeth of third. The casing will need to be mounted firmly in the vise, otherwise you will run out of hands to hold the screw driver whilst tightening the pinion nut!
    The diff assembly needs to be fitted and torqued in so that the Timkens are a little tight but the crown wheel can JUST be rotated! You need to eliminate all sources of variation. This is why the assembly must be stiffer than normal running conditions.
    Cheers Gerry
  20. #95
    16,247
    Oh .. thanks. That should be fun trying to torque up the nut on a gearbox sitting on the bench!
    seeya
  21. #96
    2,988
    seeya
    Does the gearbox fit in your vise?
    If it does not then your are welcome to bring it down here and use my vise. I know that I can get it into mine!
    Cheers Gerry
  22. #97
    16,247
    Actually ... I know an easy way ... slip it back onto the engine! with no primary shaft in there it'll just slot on! I should be able to chase a big enough vice locally
  23. #98
    2,988
    That would make things really complicated! I cannot imagine the difficulty in achieving the required precision working whilst hanging into the engine bay. Just not good enough.
    Cheers Gerry
  24. #99
    16,247
    Oh, I meant, just slide it on to tighten the nut on the front! You wouldn't need to bolt it down
  25. #100
    2,988
    Yes that would work, but what a pain sliding it on and off all the time!
    Cheers Gerry
