D Hub grease and gearbox oil
  • 1 Post By Leconte
Thread: D Hub grease and gearbox oil
    Sep 2012
    Somewhere near Mudgee, NSW
    350
    Default D Hub grease and gearbox oil
    Hi all,
    Slowly getting my D Special back together, spent a day just getting the new clutch cable in (after misplacing the ferrule) and reinstalling the handbrake cable and springs (I now have a new special tool for compressing those blasted things).
    Looking ahead to the next jobs.
    1. Can't locally source any Shell Retinax AM grease for the drive hubs, any suggestions for grease that won't attack the Teflon parts?
    2. Suggestions for oil type / brand for the gearbox ( 4 speed), I know the manual lists something but it was written 45 years ago, any new types that treat old boxes well?
    Thanks in advance
    Steve
    Symar/ca/usa
    607
    Steve,
    Don't worry about the Teflon bits - impervious to oils and greases used in the cars. Tranny oil - look for a GL-4 spec material in the 80 -90 wt range. My understanding is that some versions of the GL-5 spec fluids do not play nicely with brass syncro parts. While expensive the GL-4 spec synthetics are also good if in the proper viscosity range. The ones I am use to seeing in NA are 75-90 wt.
    Steve
    May 2012
    393
    Hi Steve,
    Consensus is with Castrol VMX80 gear box oil plus a small tube of Nulon G70 additive for the gearbox. Many many people advocate this, see thread:
    Nulon G70 - What help is it?
    For grease I have a note to self to use Castrol HTB that would have come from these forums. My car is still not on the road so I am going on other people's experience.
    cheers leconte
    UFO likes this.
    1962 Heidelberg ID19 "Axel"
    1965 Heidelberg ID19
    half owner 1974 GS 1220 Convertisseur Break
    May 2012
    393
    Hi Steve,
    The grease refereence came from a restoration post. Forum search tools are your friend, there are thousands of posts you don't see from the past unless you change your default settings or search for keywords like HTB. Halfway down this page the author asks for recommendations on oil and grease.
    http://www.aussiefrogs.com/forum/res...l-celia-7.html
    cheers and good luck with your car. Every one is a different journay, that is why it is interesting.
    Sep 2012
    350
    Thanks for the replies, I remembered seeing it mentioned but could not find it with search.
    The reason I mention the teflon issue was because it was specifically mentioned in the Haynes manual ?
    (can't refer to too many manuals right)
    Maybe they were getting a kick back from Shell?
    Steve
    Symar/ca/usa
    607
    Quote Originally Posted by Big Frog View Post
    Steve
    Over the years I have come to the conclusion that specific recommendations not also found in the factory manuals in any of the Haynes manuals should be taken with a kg of salt
    If you go here: Teflon PTFE Chemical Compatibility Reference Chart
    you will find a comprehensive list of Teflon's compatibility to a wide range of chemicals and chemical compounds (as well as a few incompatibilities).
    Steve
