D special battery warning light
Results 1 to 14 of 14
Like Tree6Likes
  • 1 Post By Hotrodelectric
  • 1 Post By ajaxvte
  • 2 Post By GreenBlood
  • 1 Post By Don B. Cilly
  • 1 Post By GreenBlood
Thread: D special battery warning light
    Aug 2011
    409
    Default D special battery warning light
    Hello
    What are possible causes for battery warning light showing at start up, and then going out again after a few minutes / kilometers? Battery appears fine. All leads to alternator, regulator etc have clean connections.
    AM
    Citroën Tragic UFO's Avatar
    9,784
    Is there actually about 13.5 volts getting to the battery at a good idle speed? Check with a voltage meter.
    San Diego, California, USA
    3,543
    Quote Originally Posted by ajaxvte View Post
    Hello
    AM
    Are you running the original regulator? I would definitely be taking Craig's suggestion as a first step. We can go from there.
    UFO likes this.
    Aug 2011
    409
    Yet another lesson. Never trust the water level indicator in a battery. A proper check of the levels revealed the need for a top up of demineralised.... Now seems all good (I replaced the regulator around a year ago. And the voltage is 13.5).
    The car had been to Canberra from Melbourne (660km) on Friday. 36 degrees Celsius. Engine got hot just short of Yass, so took a breather and topped up the radiator. Battery light started showing yesterday whilst in Canberra.
    Topped up battery water in Jugiong this morning whilst on the way back to Melbourne. 36 degrees again today. All good. Surprised that a quite new battery had lost quite a bit of water.
    Now at Chiltern in NE Victoria for a rest stop lunch.
    Other than mild overheating through the south west slopes, the car has run very well. Just a bit hot (no a/c, black roof and black targa interior) in anything over high twenties... The heat soak through the firewall is something else.
    AM
    Hotrodelectric likes this.
    8,245
    Might be worth getting a sparky to check the regulator, possibly overcharging at revs and boiling your new battery. . . certainly shouldn't be dropping levels even in those conditions.
    I tossed mine and fitted a bigger modern (in relative terms) alternator with internal regulator, the original regulators have become troublesome after 40 years.
    UFO and JohnW like this.
    08 C5 X7 HDi very Noir
    Ici.
    2,649
    you're very intrepid driving a D in the heat! sweat puddling in the footwells? I sympathize emphatically. Old cars and high temps are an unnerving combination. Especially in gridlock... I'm always glancing at the STOP light too frequently patiently waiting for it to glow
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    437
    I suggest getting one of these.
    At the price, AUD 2.40, free shipping, you might as well get 3 or 4 and give some away as presents.
    They take a while, but you usually get them in 2-3 weeks.
    addo likes this.
    Aug 2011
    409
    hmmm, well famous last words...car overheated again later this afternoon. Well, the warning light came on and as I don't have a temperature gauge I was conservative and stopped at a friend's place for dinner. Now the engine has cooled but the battery warning light has come back on - briefly - on restarting. Looks like a sparkey check will be in order. Battery and regulator are less than a year old, and alternator was rebuilt at the same time.
    8,245
    Have you checked belt tension waterpump to alternator. Your two symptoms can be related if there is slippage in these belts.
    daffyduck likes this.
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    What brand alternator did you use Chris?
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Jun 2015
    Ashburton
    226
    Quote Originally Posted by Lasya View Post
    I did the same works great and no maintenance for years. Not sure of brand but bought from atelier at reasonable cost and cones with all the right brackets
    Coffs Harbour, NSW, Australia
    625
    Beware water pump seizing !
    Richard
    Aug 2011
    409
    After all that I drove the final 200km once the car (and weather) had well and truly cooled off, with no problems. I will check all of the above once I find some time, probably this (long) weekend. Until then, I'm kind of over it for a bit!
    Los Angeles, CA USA
    1,955
    At any rate, your voltage regulator is running too hot. It shouldn't be cooking the water out of the battery. I would have that looked at.
