1970 DS - BVH query
Results 1 to 20 of 20
  • 1 Post By Citroenfan
Thread: 1970 DS - BVH query
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    754
    Default 1970 DS - BVH query
    "Vicky" my 1970 DS with BVH played up a couple of weeks ago. I'd driven it to to town to the new workshop at the machinery restoration shed to fix the fuel line. After doing the work the car would not start. With the battery starting to wane I got a lift home to return later to sort it out.
    In the process of checking over the ignition it was noticed that the vacuum advance on the Ducellier distributor was missing. However we couldn't find any obvious point on the manifold to connect to.
    Does anyone with a BVH have a hose connecting the distributor vacuum advance to the manifold? If so could you post a pic of where it attaches please?
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    11,220
    Maybe check for a small brass tube on the carbie?
    There's something about you driving Citroens into Denmark.....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Symar/ca/usa
    607
    Quote Originally Posted by rmac View Post
    Should not matter whether it is a BVH or BVM. The tube is nylon and 5x7x400mm. Unless the intake manifold has been modified/replaced there should be a short nipple on the underside of the intake manifold just to the right of water supply hose. OTOH a lot of cars (at least here in NA) had either the distributors replaced (no VA) and that nipple capped or got a non VA intake manifold at some time in their lives.
    Steve
    16,702
    It should be the other side of the throttle butterfly though ... so it needs to have a takeoff point from the carby DO NOT HOOK IT TO THE MANIFOLD DROOL TUBE !!! ( I have have seen that a couple of times ).
    shane L.
    Symar/ca/usa
    607
    shane L.
    Shane is right - what happens when you do something to late at night. Typically you will find that little take off on the mounting plate for the carburetor. On a spare engine I have it is located just below the fiber riser plate the carb sits on. In the photo it is the black capped protrusion just below the large brass carburetor mixture knob. That is the vacuum take off for the distributor. And you may well find it capped off as this one is...........
    16,702
    Quote Originally Posted by Citroenfan View Post
    I think that is still the wrong side of the throttle plate ... it's manifold side isn't it It should be obvious, I'll have a look at the cars tonight and see if I can find a DS with twin barrel carby for a piccie of it Is that a pollution car ?
    Symar/ca/usa
    607
    Hi Shane,
    The pic is from a 72 engine, LHD, and would have been pollution equipped when first sold in the US. The nipple is facing the distributor - almost a straight line in fact. I would think RHD cars would have the same basic placement with the nipple facing towards the distributor.
    Steve
    16,702
    Hi Shane,
    Steve
    I reckon it's blanked off pollution attachment points. The dizzie advance has to be on the carby itself
    Symar/ca/usa
    607
    Hi Shane,
    AFAIK that 'port' is the only vacuum source for either the dizzy or the air pump's gulp valve. And, if I remember correctly (keeping in mind that we are going back some 40+ years here) is the reason why later USA cars that were pollution controlled equipped did not have VA dizzies. And I could not find any real definitive illustrations in any of the relevant parts books either . But if Mac's car does have that little port on the intake manifold it could be used as a vacuum source for the distributor using a suitable hose. If his car does not, I really cannot think of any other place where a suitable vacuum would be found.
    Steve
    754
    Thanks for the pic citrofan. I've found the top two knobs/nuts but there is no nipple underneath it on mine. Being a BVH there is not much room around the carbie with the hydraulic bits hanging on there. Even feeling, where I can get my fat fingers into I can't feel anything.
    Thanks also to the other contributions. Do I make the correct inference that the tube is not vital/important?
    Current Cars
    1991 Mazda E2200
    Feb 2012
    Ongar / England
    868
    Hello, ignore it. It couldn't have been connected for ages. Is the car running properly now? Spending your money for you (my wife does that to me all the time), buy a 123 dizzy.
    Peter
    Los Angeles, CA USA
    1,955
    The nipple underneath (US cars) was for the pollution control gulp valve. AFAIK, know D was ever delivered with a vacuum advance dizzy. Methinks some well meaning smart guy put Peugeot parts on your CitroŽn.
    11,220
    Quote Originally Posted by badabec View Post
    Hello, ignore it. It couldn't have been connected for ages. Is the car running properly now? Spending your money for you (my wife does that to me all the time), buy a 123 dizzy. Peter
    I certainly agree with the 123.
    I've never looked closely at a DS in this regard, but Shane and I are sort of saying the same thing. My Solex carbies have a brass tube on the main body of the carbie or the top cover, going directly to the distributor vacuum advance. My 123 has a vacuum pipe too, to the Weber carbie, not to the manifold.
    Cupla phone calls to Perth perhaps Ross? What does your other DS have? I recall SKP had serviced it that time I drove it down to Denmark (ANY time you need that doing again....) and he'd know.
    The other thing that occurs to me is that the car should be running like a pig if there is a vacuum leak due to the tube not being connected where it had been before.
    Symar/ca/usa
    607
    Quote Originally Posted by daffyduck View Post
    Actually my parents 62 ID had a vacuum advance dizzy - but have never seen a 5 main car with one here in the US.
    From the 123 website and seems to explain it
    123\DS-A is a distributor, specifically targeted for the Citroen ID/DS. It contains all the curves for carbureted ID/DS-engines as originally specified by Citroen, for cars after July 1959.
    With a switch you can easily choose the advance-curve that was specified for your engine.
    It comes with an angled distributor-cap, for easy access to the sparkplug-leads.
    Might you prefer un upright cap, please specify a '123\DS-R'
    For ID's until 2/1964 Citroen used a distributor with vacuum-advance. To replace this you should order a '123\DS-R-V'.
    ID-19B's from 9-'66 until 9-'68 with 'DV'-engine , and DS19A / DS19MA & ID19FA with 'DY'-engine from '65 to '68 require a different fixation. For these cars we offer a '123\DV-R' with a special mounting bracket.
    Steve
    Los Angeles, CA USA
    1,955
    Well? A 1962 is certainly not a 1970 which is the subject at hand.
    Symar/ca/usa
    607
    Well as mentioned earlier have never seen a later (5 main) car with one . OTOH Mac might do well to replace his with the appropriate 123 - did on my two D's and could not be happier. Just ordered one for the 2CV also.
    Steve
    754
    Cost is the major obstacle to using a 123 unfortunately. With the volatility in the financial markets our super has taken a bit of a slide and "discretionary" spending has become a bit more problematic.
    Current Cars
    1991 Mazda E2200
    16,702
    I don't think I'd go the 123 route .... I'd order in a trigger wheel and convert the car to megasquirt and megajolt Oneday I'm going to do this ... I'm itching to mess with one of those kits when I have some $$$ and time.
    11,220
    Yes, quite understand. The Hot Spark compromise is a good one if the dizzie is in reasonable order.
    I bought the 123 when I was still working more or less full time (NOT doing that now, and greatly enjoying improved life style!).
    Symar/ca/usa
    607
    I understand also - in my case with the 72 I more or less was forced into the 123. I had the cam redone during its engine overhaul and in the process a more aggressive profile was done. When back together I just could not get the dizzy's advance correct changing springs and fiddeling with its cam profile. So took the plunge (thing was fairly worn out anyway) and got the 123 with the adjustable curve settings. Found, a bit to my surprise, that the advance setting for a late model 23 EI car worked just fine with the modified 2.1 engine. 138,000 miles later (with the 123) and have never looked back. The other thing I did later on was install a set of NGK Iridium plugs and a very high voltage coil (60,000 volts). Increased the plug gap about 40% over normal (0.38"). Engine runs a charm. On trips I have taken with the car over the years avg fuel economy is in the range of 27mph (US gallons) at speeds in the 75+ range.
    Like Shane I had/have looked at the MegaSquirt system. OTOH not real sure that it would improve anything at this point.
    Steve
    JohnW likes this.
