rim & tyre sizes
Results 1 to 11 of 11
    Feb 2005
    rosevale/tasmania
    2,720
    Default rim & tyre sizes
    No doubt I could hunt around the web & find things out but you guys probably already know the answers so:
    Would someone be able to tell me the standard tyre sizes & rim widths for:
    - Light 15
    - ID & DS
    - CX
    - SM
    - BX
    I would like to eventually know these dimensions for all variants of these models.
    thanks in advance, Peter
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,025
    Hi Peter
    The traction post 1938 4 cylinder is 400mm across the rim bead seat, and 115mm between the rim bead flanges. Tyre size is 165x 400mm.
    I do not have a rim from the Six Cylinder traction to measure up but as they take a 185x400mm tyre I assume that the distance across the rim bead flange inner faces would be 20mm more that the rim for the 4 cylinder car.
    Cheers Gerry
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    The standard CX steel rims are 5.5" rims, the alloy rims are 6" rims, both 14" diameter. That leaves out the TRX rims which are only suitable for TRX tyres or the Avon equivalents.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Fellow Frogger! Buttercup's Avatar
    Jan 2013
    Lake Keepit NSW
    818
    Early DS19 (french) Front 165x400, Rear 155x400,
    Early DS19 (Slough) and ID19 until July 65 165x400
    All D types After July 65 185R15
    Bob
    '57 Slough DS19, Buttercup
    '60 2CV 1220, Raid Runner
    Several DS19 and 2CV projects
    Feb 2005
    rosevale/tasmania
    2,720
    excellent; thanks to all so far :-)
    cheers! Peter
    9,670
    The DS also had a 180x15 rim. The round hole in the middle of the rim vs the 185 square 'hole' (if such a thing exists!).
    Some 400mm cars will likely have 15 inch conversions. Maybe, this pink 1960 ID19
    Citroen ID 19 1960 CAR in VIC | eBay (Yes, relisted. $3,500 start.)
    is one such car as it has crossplies fitted.
    Feb 2005
    rosevale/tasmania
    2,720
    what is the rim width for the round hole rim?
    3,025
    Look again, they are retreaded Michelin X
    Cheers Gerry
    Jan 2013
    Lake Keepit NSW
    818
    No... I think David is correct...
    On original 400 rims, the centre disc stands proud of a line across the rim face....
    In these pics it seems to be inside that line... like a 15" conversion.
    Bob
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    330
    SM started with 195 70 15, then went to 205 70 15 and some people fit 215 65 15, which are close fit under the rear wheel spats. Michelin XWX was the tyre. Wheels are 6 inch wide.
    The post 1966 D wheels will fit SM (and vice versa) but SM wheels have very large centre hole for the mounting bracket that holds the wheel-trim in place.
    205 70 15's on the front of a DS does reduce wheelspin from standing start if you're keen I ran my D Safari on that size for many years.
    The old Ford Transit van wheels have the same bolt pattern and PCD as the SM and D, 5x160, so there's s few modern alloys out there to cringe at.
    cheers
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Feb 2005
    rosevale/tasmania
    2,720
    again my thanks to all
    BX seems to be major missing bit - any joy?
    cheers! Peter
