DSuper5 engine mounts
Results 1 to 2 of 2
  • 1 Post By marc61
Thread: DSuper5 engine mounts
    Feb 2012
    Ongar / England
    868
    Default DSuper5 engine mounts
    Hello, engine mounts. One has small bolt in the bottom which threads into the main big bolt. The other has a nasty blob of weld.
    How do I replace the rubber donuts? With the small bolt removed, nothing much else happens. Once I've ground away the blob of weld or removed the small bolt, then what?
    Does the big bolt pull or push out?
    Do I have to 'do a Buttercup' and tie one end to tree, the other to my 'Ute' and drive off?
    Peter
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    350
    There's 2 rivets on each side that need to be drilled out, which hold the base to the shell around the rubber. Then it'll come apart.
    cheers
    Marc
    badabec likes this.
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
