CX Spheres
Thread: CX Spheres
    Symar/ca/usa
    607
    Default CX Spheres
    An acquaintance asked me a question about CX spheres and I do not have the info to correctly answer him. He has a number of CX spheres and was asking how to differentiate amongst the various units. I know that the sedans use 75 bar fronts and 40 bar rears (Breaks use a 35 bar rear) and that the GTI model units are different (different shock valving - I have to assume). Is there a way of looking at the exposed end of the shock to determine which model they go on. For example with D's/SM's it is dead easy as the by-pass holes are of completely different sizes as well as the addition of an extra shim for the SM rears. And the CX units I am aware of are some what in between. But between the various CX models I have nothing. Anyone able to provide better info?
    TIA
    Steve
    Don't remind me!
    16,609
    Are there not small etched numbers at the damper end?
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,894
    GSF Car parts used to have a really good Citroen Spheres website that had car model, size, pressure and damper hole measurement. Does anyone have a copy of this offline?
    Cheers, Ken
    Don't remind me!
    16,609
    Hi Ken,
    Is this the table to which you refer?
    http://www.pratbyran.se/attachment.p...5&d=1200239478
    Regards, Adam.
    North Brisbane
    1,894
    That is the one. Has some hole diameters missing but has most.
    Cheers, Ken
    Symar/ca/usa
    607
    Hi Ken,
    Regards, Adam.
    Thanks Adam,
    Exactly what I was looking for.
    FYI D Fronts (all models) 1.80mm, D rears (all models) 1.60mm , SM front 1.45mm, SM rear 1.25mm.
    In looking at the table pdf it would seem that the CX units I have re-gassed for folks have been the GTI ones as the hole sizes correspond to what I have listed in my notes.
    Older style replaceable shocks for D models - 2.00mm front and rear. If anyone needs them I have a fairly complete set of valving and shim differences for the various D models also.
    Steve
