C3 hazard light
Results 1 to 9 of 9
  • 1 Post By addo
Thread: C3 hazard light
    Feb 2016
    Little mountain qld
    1
    Default C3 hazard light
    Hi,Frogies my first post just bought a c3 hdi and hazard lights have mind of there own,came on by themselves and won't cancel
    Any thoughts on this prob.would be appreciated. Stancikas0
    9,332
    Early C3 (the uncommon late one is quite different)? Did the flashing not stop when the remote was used ?
    PS Was this after a battery disconnect? The cars do very odd things if the computer isn't put to sleep.
    San Diego, California, USA
    3,543
    I'm with Seasink on this. Check your battery condition. Body control modules tend to do some bizarre things if the battery isn't 100%, both at rest and running. We can go from there.
    Don't remind me!
    16,609
    I'm wondering if it's a COMM unit fault myself.
    9,332
    It could be a COMM (the unit with the indicator stalks). The best clue will be what action triggered this.
    3,543
    Is the hazard switch part of the stalk?
    Don't remind me!
    16,609
    I looked at the earlier C3 wiring. The four-way flashers simply ground out one terminal of the instrument panel harness, if there's no underlying problem and they won't stop I reckon a physical short inside the panel is possible.
    3,543
    Ah- OK. A ground signal into the control module completing the transistor circuit. I'm assuming you can unplug the panel or the stalk and see if the lamps go out?
    Don't remind me!
    16,609
    If they stay on when the switch is unplugged (centre panel, above radio), then the next experiment would be unplugging the instrument panel. If they still run it's a fault downstream.
    Hotrodelectric likes this.
