DS Valeo starter motor
Results 1 to 13 of 13
Like Tree4Likes
  • 1 Post By daffyduck
  • 1 Post By GreenBlood
  • 2 Post By badabec
Thread: DS Valeo starter motor
    Feb 2012
    Ongar / England
    868
    Default DS Valeo starter motor
    Hello, I've read lots of old posts about fitting a Valeo starter motor.
    I know Darrin sells them but I'm a cheapskate
    I have a tame auto electrician with a mountain of old starters.
    To which cars was the Valeo starter originally fitted? Is there a part number? Or type?
    Peter
    San Diego, California, USA
    3,543
    Well, there's your problem. Your auto electrician is tame. Hit him a few times with HEI. He'll perk right up.
    I'll see and have a look. I think more than anything else you want to match the diameter of the gear, and the number of teeth. Matching up the mount end will be rather important too. You may wind up making an adapter plate of some sort.
    Los Angeles, CA USA
    1,955
    Google: Titus starter for Citroën DS. Somewhat less expensive than the Valeo units.
    Lasya likes this.
    10,116
    I thought it was used on a C35. Valeo D9 something. It needs an added peg and the top extension to hold the heat shield.
    It's supposedly a high torque unit, but doesn't have a reduction gear.
    3,543
    I went looking at that one for Darrin. That is a lot of machine work on that mouth end that you would have to do on whatever it is you find. Not horrible on money, though. I know the one from John Titus works, but with shipping there will be a little sticker shock. The one David is talking about is I think a CX unit- isn't that what the C35 engine is based on? More diving into the parts books......
    8,249
    Icon3
    Quote Originally Posted by badabec View Post
    Peter
    This appears to be the Valeo starter to suit the late D cars (or was)* Part No. 433221 - Note it is shown as a re-manufactured part out of Poland.
    *I say was because I understand these are now supplied unbranded
    This site gives a range of cross reference part numbers which might help your 'tame auto electrician' he may need to be made aware of the spin direction for a D motor
    Wood Auto Supplies Ltd :: D9E104
    Attached Thumbnails Attached Thumbnails DS Valeo starter motor-valeo-starter-433221.jpg
    Hotrodelectric likes this.
    08 C5 X7 HDi very Noir
    Don't remind me!
    16,609
    Interesting range of cross-references!
    https://en.as-pl.com/c/all/433221
    8,249
    Icon11
    That S5162 looks totally wrong!! 2 mount holes, and if the images are accurate it looks way to big. CW rotation
    Look here, as in my previous post
    Don't remind me!
    16,609
    It's wholly possible the listing is screwed up.
    Feb 2012
    Ongar / England
    868
    Hello, I think I'll just stop being cheapskate and pay up. Buy cheap, buy twice.....
    Thanks for all the information
    Peter
    GreenBlood and UFO like this.
    Citroën Tragic UFO's Avatar
    9,787
    Having done that job twice, the last time with a C35 starter, you are correct. Do it once!
    10,116
    The model number Chris notes would be the one, but there is no guarantee it will last forever. I've had to change one of these starters, which was a letdown as it had done very little work. I suspect an assembly problem with a brush spring in that case. If you have to dismantle one of these, note the LH thread for the end screw (note little arrow) and you fit the brush springs and their little plastic retainers after the main assembly.
    Los Angeles, CA USA
    1,955
    The Titus unit is made in USA. Titus should get points from president Obama for job creation.
