TA gearbox locked
Results 1 to 12 of 12
  • 1 Post By Trading Estate
Thread: TA gearbox locked
    Jan 2016
    Montevideo /Uruguay
    16
    Default TA gearbox locked
    Hi everybody:
    while the car is parked in a garage, someone stepped in and played with the lever : now something is broken and there are two selected speeds ?? Please anyone knows how to unlock this.
    Thanks a lot
    Zeque
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    558
    The problem will be under the dash , get a torch and lie on the floor and look behind the dash.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Fellow Frogger! Trading Estate's Avatar
    585
    The selector rods can get jammed as suggested. Wiggle the tower on top of the gear box if the fiddle under the dash doesn't work. happened to me that it all locked up in Camberwell junction once!
    addo likes this.
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Jan 2016
    Montevideo /Uruguay
    16
    I disconnected the rods but it still jammed. Is it not dangerous to force or wiggle on the tower? Is it needed to press the clutch or to raise one wheels while doing that?
    I have done: I would like to take out the device under the dash to rebuild, but I could not even after removing the nut that holds it. Is it a manual or procedure to remove it?
    Thank you very much fellows
    Fellow Frogger! tractionfan's Avatar
    280
    You shouldn't be able to change gear in a TA without the clutch being pressed.
    Jan 2016
    Montevideo /Uruguay
    16
    Yes, you are right :-) I 'll get a helper to press clutch
    Jan 2016
    Montevideo /Uruguay
    16
    Quote Originally Posted by tractionfan View Post
    OK, I unlock the gears °°
    I am new to TA and I'll look for a TA user manual.
    quote from Wikipedia:"The gear change was set in the dashboard, with the lever protruding through a vertical, H-shaped gate.Because this vertical orientation could have resulted in the car dropping out of gear when the lever was in the upper positions (i.e. second or reverse gears), the gear-shift mechanism was locked when the mechanical clutch was engaged and released when the clutch pedal was depressed."
    Where is physically the lock?
    Thank you again
    9,329
    Newcastle
    2,755
    Default Gear Lock
    Quote Originally Posted by Zeque View Post
    Thank you again
    Hi,
    The lock is built into the clutch bellhousing and at the base of the external gearchange mechanism. It can be a bit worn and out of adjustment and so people can possibly force it to move without the clutch being pressed.
    Not sure I totally agree with the reason given for this lock on Wikepedia. I understood it was found to be necessary due to the very unusual flexible mountings used for the TA etc. However not important really
    I see you have been given the reference to a copy of the original factory manual. Note it is in two parts so get both ! The words and the diagrams are in seperate parts !
    Good luck jaahn
    9,329
    I should have said: Shane's goodies - Index of /ShaneCD Diagrams are there.
    16,695
    Wow ... That stuff is still around. That has to from the early 2000's.
    Jan 2016
    Montevideo /Uruguay
    16
    Hi:Thank you all for the info.I also found this place http://www.ctaservice.se/CTA-Tech.htmI will need to service the selector under the dash. Is it a trick to remove it?
